Re: What is the best product to clean white letter tires
[Re: Pacnorthcuda]
#2783294
06/09/20 03:54 PM
06/09/20 03:54 PM
Posts: 5,349 Planet Earth
RoadRunnerLuva
Planet Earth
I use to use Formula 409 or "Fantastik" kitchen countertop cleaner....IIRC same stuff as the old "Bleach-white" tire cleaner from the parts store. As Pacnorth mentioned, just use on the letters only, then use whatever tire shine you want on the rest.
Plymouth Makes It!
[Re: robertop]
#2783316
06/09/20 05:05 PM
06/09/20 05:05 PM
Posts: 1,115 Usa
A39Coronet
Usa
Grill brush with metal bristles and standard strength degreaser. Worked at a carwash in highschool and that's all we used, makes them shine like new.
[Re: robertop]
#2783394
06/09/20 08:13 PM
06/09/20 08:13 PM
Posts: 203 Alabama
David1971
Alabama
Welcome to the club! Here are my before and after pictures...after about a year's time spent in the garage.
[Re: David1971]
#2783470
06/09/20 11:41 PM
06/09/20 11:41 PM
Posts: 1,250 North Carolina
469runner
North Carolina
Yes, Raised brown letter tires. Sorry to tell you, there is nothing that will get those letters white again. It is a defect in the manufacturing of the tires. I thought by now maybe it had been rectified. Something in the compound of the rubber is staining the lettering. You could scrape, sand, chemically treat them, etc. Nothing works. The letters are that color now. I tried painting mine. Very tedious, and did not last. I will never buy another BFG tire again after this. Unfortunately, as little as I drive my cars, I'll be looking at the brown letters for a long time.
[Re: Pacnorthcuda]
#2783512
06/10/20 05:56 AM
06/10/20 05:56 AM
Posts: 18,160 Mass
DAYCLONA
Mass
I use to use lacquer thinner. Carefully applied from a cloth stretched over my finger. Just wipe the white. Worked really well, but it discoloring the black a little if you are sloppy. Tire shine will remedy that though. Same method, but I've been using trichlorethylene for decades...removes the "browning" that most WLT's experience
[Re: 469runner]
#2783560
06/10/20 09:39 AM
06/10/20 09:39 AM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Yes, Raised brown letter tires. Sorry to tell you, there is nothing that will get those letters white again. It is a defect in the manufacturing of the tires. I thought by now maybe it had been rectified. Something in the compound of the rubber is staining the lettering. You could scrape, sand, chemically treat them, etc. Nothing works. The letters are that color now. I tried painting mine. Very tedious, and did not last. I will never buy another BFG tire again after this. Unfortunately, as little as I drive my cars, I'll be looking at the brown letters for a long time. Yep, BFG lost a sale from me. Last fall I bought a set of Mickey Thompsons. I love the look of the TA's, but didn't want "raised brown letter tires".
[Re: David1971]
#2783582
06/10/20 10:40 AM
06/10/20 10:40 AM
Posts: 2,105 New Mexico
JMCFAN
New Mexico
Welcome to the club! Here are my before and after pictures...after about a year's time spent in the garage. David1971 what did you use? Looks great
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: JMCFAN]
#2783597
06/10/20 11:12 AM
06/10/20 11:12 AM
Posts: 203 Alabama
David1971
Alabama
Welcome to the club! Here are my before and after pictures...after about a year's time spent in the garage. David1971 what did you use? Looks great My apologies JMCFAN. My post is confusing and misleading. The "before" picture is when the TA's were brand new. I shot that picture shortly after I removed the blue dye from the lettering and cleaned the complete tire, both front and back...including the blackwalls. Then I applied some rubber/vinyl protectent. Yea, they looked fantastic at that moment. Then as you all know, it is all downhill from that point. By the way, the blackwalls are now discolored also. David
[Re: David1971]
#2783605
06/10/20 11:30 AM
06/10/20 11:30 AM
JMCFAN
New Mexico
Welcome to the club! Here are my before and after pictures...after about a year's time spent in the garage. David1971 what did you use? Looks great My apologies JMCFAN. My post is confusing and misleading. The "before" picture is when the TA's were brand new. I shot that picture shortly after I removed the blue dye from the lettering and cleaned the complete tire, both front and back...including the blackwalls. Then I applied some rubber/vinyl protectent. Yea, they looked fantastic at that moment. Then as you all know, it is all downhill from that point. By the way, the blackwalls are now discolored also. David oh ok....that makes sense. I used lacquer thinner last night...worked pretty well
[Re: maximus]
#2783627
06/10/20 12:15 PM
06/10/20 12:15 PM
Posts: 736 New York
R/T1968R/T
New York
Been using this with a stiff brush for over 40 years! works great. I think they were bought out by Black Magic Co.
[Re: JMCFAN]
#2783656
06/10/20 01:00 PM
06/10/20 01:00 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Welcome to the club! Here are my before and after pictures...after about a year's time spent in the garage. David1971 what did you use? Looks great My apologies JMCFAN. My post is confusing and misleading. The "before" picture is when the TA's were brand new. I shot that picture shortly after I removed the blue dye from the lettering and cleaned the complete tire, both front and back...including the blackwalls. Then I applied some rubber/vinyl protectent. Yea, they looked fantastic at that moment. Then as you all know, it is all downhill from that point. By the way, the blackwalls are now discolored also. David oh ok....that makes sense. I used lacquer thinner last night...worked pretty well Glad it worked for you, worked for me for years. Now I have Goodyears that don’t have that problem.
[Re: Pacnorthcuda]
#2783775
06/10/20 04:28 PM
06/10/20 04:28 PM
318 Stroker
St. Louis, Mo
[/quote]Glad it worked for you, worked for me for years. Now I have Goodyears that don’t have that problem. [/quote]
What Goodyears do you have, and how old are they? When I put the M/T's on last fall, I replaced my Goodyear Eagle GT II's that were 16 years old. I loved them, only had 17,000 miles, but I felt that they had aged out, and were a ticking time bomb, even though there was no dry rot. I wanted new Goodyears, but they quit making a 15" white letter performance radial a long time ago. Do you have Polyglas?
[Re: 318 Stroker]
#2783782
06/10/20 04:47 PM
06/10/20 04:47 PM
Pacnorthcuda
Glad it worked for you, worked for me for years. Now I have Goodyears that don’t have that problem. [/quote] What Goodyears do you have, and how old are they? When I put the M/T's on last fall, I replaced my Goodyear Eagle GT II's that were 16 years old. I loved them, only had 17,000 miles, but I felt that they had aged out, and were a ticking time bomb, even though there was no dry rot. I wanted new Goodyears, but they quit making a 15" white letter performance radial a long time ago. Do you have Polyglas? [/quote] Mine are Goodyear Eagle GT ll’s too. Purchased around 2006 so just about as old. Probably only 15,000 on them. Always garaged. I’m not to worried about catastrophic failure, I figure I’ll get a warning of some sort. If I ever replace I will probably got to MT Sportsman’s.
