Re: 72 Swinger Track day/ProTour practice car
[Re: V8val]
#2730423
01/05/20 10:04 PM
01/05/20 10:04 PM
Posts: 24,328 Capital of Narcissism
jcc
No soup for you!!!
No soup for you!!!
75 So this is the EFI TR going in the car. I made a few changes, added a burst relief spring valve, did a little lightening, as they are rather porky, added two paired rear head water inlet ports, which I am not sure is anything more then following the herd, I epoxied/insulated internally front water manifold crossover, I cut out the cam valley cover and replaced with a Ti sheet metal cover( saves weight and insulated better then other metals). pic shows CF honeycomb which i decided not to use. The EFI plumbing shows fuel supply crossovers front and rear, front crossover having an upward arch to trap air, to provide an injector impulse cushion(?) for the fuel pressure Feed is driver side, Return is Pass side.
[Re: jcc]
#2730427
01/05/20 10:20 PM
01/05/20 10:20 PM
jcc
No soup for you!!!
No soup for you!!!
78
I have my Diff cooler exhausting right above my tag. Trying to clean that area up, and decided to remove center lower notch from the OEM bumper, getting bumper chrome straight is tough, I'm working at it. I had the chrome chemically stripped by the chrome shop before starting on the bumpers. I started with two used old bumpers, one was a donor for grafting, picked the straightest one, , but it had a little backside rust I disregarded. Unfortunately the rust turned out to be very deep and when welding and I blew right thru the bumper, you can see the two rust holes on the right, bumper in pic is upside down, another SNAFU.. I tacked the bumper to a 12" steel I beam to keep everything straight..
[Re: jcc]
#2737256
01/27/20 08:27 PM
01/27/20 08:27 PM
jcc
No soup for you!!!
No soup for you!!!
#82
So I got the basic center shell done. It came out just OK. because the foam plug was not solid, it was hard to do a proper vac bag composite, so I did hand layup. If I did it again, I would go 4lb solid foam (rather then build up) and vac bag.The pic is a test fit, I need to trim the front around the rear axle travel arc, and the whole shell elevates another 2+" upward. I'm waiting on the hi temp epoxy to arrive to build the side wing diffusers ( they both will have slightly steeper more robust curvature) that cover the exhaust/mufflers.
Its coming in trimmed at around 8lbs, which is pretty much on target, its the most robust piece since it will likely get the most abuse from being the lowest and longest from road debris, curb scrapes, etc. The project was targeted for 25lbs with the two larger side wing diffusers, which are as mentioned previously larger. The trade off was the weight is all behind the rear axle for improved F/R balance, and its all much below COG height.
[Re: jcc]
#2765711
04/18/20 09:50 PM
04/18/20 09:50 PM
jcc
No soup for you!!!
No soup for you!!!
#83
Here are the two fuel cell side diffuser tunnel "plugs", in this pic you are viewing the bottom, and the right side is the rear, and the flared ends will contain openings for the dual exhaust outlets. Difficult to spot, but their main flair curve is greater then the fuel cell cover.
[Re: jcc]
#2767663
04/23/20 09:24 PM
04/23/20 09:24 PM
jcc
No soup for you!!!
No soup for you!!!
#87 So before I get this diffuser too far along, I need to get the exhaust routed and installed, as the diffuser wraps around a lot of it. The SS mufflers pictured are straight thru 2.5" the offset end is the out, the center is the in. I chopped off the slip fit connectors, and turned down (shortened) the V clamp fittings to shorten the whole assembly as much as possible. The mufflers will be installed vertically instead of the normal flat orientation. I expect to have a pair of slip on custom heat blankets made up, since the mufflers are so close to high temp epoxy CF and the fuel cell. There will be vehicle speed limited air flow surrounding the blanketed muffler when installed. Pondered which end (Male/Female) of the V clamp flange should go on which end (in/Out). You can view my decision.
