Re: Edm hydraulic lifter,with pushrod oiling
[Re: 72sat]
#2780330
06/01/20 01:00 PM
06/01/20 01:00 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
If you have more than .0010 lifter to lifter bore clearances, most of the ones I've measured are all over .0025 ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) , you don't need EDM oiling for that block or camshaft ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Use the money you save from that on some other better part ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: 383man]
#2782873
06/08/20 04:04 PM
06/08/20 04:04 PM
fast68plymouth
So. Burlington, Vt.
It’s hard for a hydraulic lifter to function properly when there is a .020” hole in the bottom of it, leaking oil out.
Get some Crower Camsaver lifters for an AMC v8. Those will have added oil to the cam and pushrod oiling.
[Re: CSK]
#2783021
06/08/20 08:49 PM
06/08/20 08:49 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have Howard's solid EDM lifters in my car and they are AMC type lifters with pushrod oiling. They were a good lifter and I only lost about 10 PSI oil pressure but I think it's a good trade off putting the oil where it needs to go when idling on the street. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: J. Hammer]
#2783245
06/09/20 02:27 PM
06/09/20 02:27 PM
fast68plymouth
So. Burlington, Vt.
See my previous post.
Or better yet....... post a part number for the lifters you’re asking about people’s experiences with.
[Re: fast68plymouth]
#2783309
06/09/20 04:29 PM
06/09/20 04:29 PM
Posts: 3,916 usa
lewtot184
usa
if the hole in the hydraulic tappet is underneath the tappet oil reservoir (which a hydraulic tappet has to have and maintain) and it's "constantly" leaking how's it supposed to work? wouldn't the tappet collapse everytime the engine is shut off? just asking.
