Re: torqueflite pan gasket
[Re: AndyF]
#2782509
06/07/20 07:34 PM
06/07/20 07:34 PM
Posts: 3,916 usa
lewtot184
usa
Good question. I have the Mopar gasket on the 727 in my Duster and it has also always weeped a little bit. There is always a drip or two under the car. It doesn't actually leak, it just weeps enough to coat the surface of the pan then once in awhile a drop forms and lands on the floor. About one drop a day. I'm going to try a different gasket too. I'm thinking I'll try the Moroso soft rubber one to see if it seals better with the Moroso aluminum pan that I have. i'll take a look at the moroso. I don't think your suppose to rtv the gaskets; been using hi-tack.
[Re: lewtot184]
#2782516
06/07/20 07:58 PM
06/07/20 07:58 PM
Posts: 2,858 Pattison Texas
CSK
Pattison Texas
I reuse the black Mopar one, I have had the pan off & on about 5 times on my A518, dry as can be,
[Re: lewtot184]
#2782646
06/08/20 09:12 AM
06/08/20 09:12 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I've been using the mopar black (reuseable?, but I never re-use them) gaskets for years, and for years they always weep, drip, or leak. what's a better gasket that will keep things dry? I never had any luck with that gasket. I just use the black rubber gasket that comes with the filter from Advance Auto, no weeping.
[Re: A727Tflite]
#2782650
06/08/20 09:49 AM
06/08/20 09:49 AM
Posts: 3,916 usa
lewtot184
usa
All gasket styles require a flat pan flange.
I’m betting if you take the pan off and lay it on a flat surface you will see out of flat areas, belled bolt hole, etc.
The reason we went from cork to the reuseable was the cork weeped after being in service because it lost compression from shrinkage.
All our warranty pretty much dried up after doing that, pun intended. checking for a flat gasket surface will be done. I use the mopar deep pans and i'm careful about over torqueing. using a cast alum pan may hang down a little further than I want but i'll measure for that option.
[Re: lewtot184]
#2782660
06/08/20 10:20 AM
06/08/20 10:20 AM
RapidRobert
X3 on confirming flat rails & as you know side to side torquing & not overtight
[Re: lewtot184]
#2782743
06/08/20 12:41 PM
06/08/20 12:41 PM
Posts: 3,076 Michigan
A727Tflite
are the bolt holes for the pan blind holes? I haven't had either trans pan off in a couple of years and don't remember. Some are blind and some are not. Someone else said they were never lucky using this gasket. Sealing the pan up is not about luck, it’s about being thorough. It’s been a while since I ran a study at work, but if I recall the pan flange has to be flat within .013”. That means you cannot insert a .013” feeler gauge between the flange and flat surface. The most common issue with stamped steel pans is when someone has “bell mouthed” the bolt hole areas in the pan. That usually happens when someone tried to seal the pan up by over torquing the bolts when using a cork or composite gasket. Again, you can’t over tighten the reuseable gasket because the plastic backbone prevents that. You will strip the case bolts before that happens.
[Re: A727Tflite]
#2782753
06/08/20 01:02 PM
06/08/20 01:02 PM
Posts: 3,916 usa
lewtot184
usa
are the bolt holes for the pan blind holes? I haven't had either trans pan off in a couple of years and don't remember. Some are blind and some are not. Someone else said they were never lucky using this gasket. Sealing the pan up is not about luck, it’s about being thorough. It’s been a while since I ran a study at work, but if I recall the pan flange has to be flat within .013”. That means you cannot insert a .013” feeler gauge between the flange and flat surface. The most common issue with stamped steel pans is when someone has “bell mouthed” the bolt hole areas in the pan. That usually happens when someone tried to seal the pan up by over torquing the bolts when using a cork or composite gasket. Again, you can’t over tighten the reuseable gasket because the plastic backbone prevents that. You will strip the case bolts before that happens. thanks
[Re: A727Tflite]
#2783426
06/09/20 09:45 PM
06/09/20 09:45 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
The black reuseable Mopar production gasket has torque limiters built in, you can’t overtighten the gasket. If you truly have a wet pan gasket you either have a leak from something/somewhere else or your pan is not perfectly flat.
Don’t use any sealer on this gasket, it’s not needed. I’ve reused the one n my 47RE at least four times. I’ve also reused the one on my 727 w/t 47RE pan several times. 125 inch lbs.... no leaks ever! Lucky me!! That gasket and the chevy style umbrella seal for the dipstick tube were great advancements in torqueflight sealing
