Re: 543 440 Combo's
[Re: Dragula]
#2781441
06/04/20 05:07 PM
06/04/20 05:07 PM
birdtracker
this should be really interesting. I would like to hear your bore and stroke thoughts. I did have a 4.375 stroke crank in a RB iron block with only a little grinding. Birdtracker
Re: 543 440 Combo's
[Re: Dragula]
#2781579
06/05/20 01:14 AM
06/05/20 01:14 AM
Posts: 43,248 Bend,OR USA
Cab_Burge
Which stock block, year and type, B, RB hemi I wouldn't waste my time or money on using a girdle in any stock RB or B block I do use aluminum main caps and ARP main suds on the 400 blocks I build if they sonic test good Buy a good block and have fun making a lot of power
Re: 543 440 Combo's
[Re: Dragula]
#2781653
06/05/20 11:18 AM
06/05/20 11:18 AM
Posts: 16,928 NC
440Jim
NC
Depends on power level. Turning 2000 rpm on the street should not be a problem. Making over 800 hp, I would want a better block.
Re: 543 440 Combo's
[Re: 440Jim]
#2781774
06/05/20 02:51 PM
06/05/20 02:51 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m not sure which combo the “543” is.
4.375 x 4.500 is 541.2 4.380 x 4.500 is 542.4 4.500 x 4.250 is 540.7 4.440 x 4.375 is 541.9
Re: 543 440 Combo's
[Re: fast68plymouth]
#2781898
06/05/20 09:10 PM
06/05/20 09:10 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
4.375 x 4.500 is 541.2 4.380 x 4.500 is 542.4 4.500 x 4.250 is 540.7 4.440 x 4.375 is 541.9 You know Dwayne, I never could figure out what a 472 crate hemi was either. 4.25 x 4.150 = 470.9 Did "471" sound too much like a Ford product? Not sure what the logic was there. We will never know. But I do remember the part number was P5249666. As in "mark of the beast" if you believe such things LOL
Rich H.
Esse Quam Videri
Re: 543 440 Combo's
[Re: ZIPPY]
#2781925
06/05/20 10:07 PM
06/05/20 10:07 PM
Posts: 12,402 Taxes & Virus's R-US, NY
Dragula
Just curious who has built one in a stock block, and how hard did you lean on it.....We have a ton of the 512 builds running around here. Fastest one was mine at 9.70 at 138.5mph on pump gas which my little 400/512 has eclipsed to a 9.60...We even have one of the 526 builds running real strong in my buddies car, so the obvious question is how would the 543 fair? http://store.440source.com/Stroker-Kits/products/3/440 >> 543. (4.500" stroke/7.100" rod)
Re: 543 440 Combo's
[Re: Dragula]
#2781995
06/06/20 08:27 AM
06/06/20 08:27 AM
ZIPPY
S.E. Michigan
Well, here is another bump... I'd like to know just for info.
Rich H.
Esse Quam Videri
Re: 543 440 Combo's
[Re: mopar dave]
#2782144
06/06/20 02:31 PM
06/06/20 02:31 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
FWIW the 512" low deck in my Valiant went 9.0's at 150 NA. SO you can certainly can make some steam this way. Will it live a long happy life, mine sure didn't. It went 100ish passes before the block gave out. Yes it had aluminum caps. Im pretty sure the 900ish HP from an NA combo in a stock block was just to much for the ole gal. I don't really know the power as it was never on the dyno but went 150 at 3470lbs so 900ish. When I did it they were between iron blocks and didn't have the $$$ for aluminum. I learned my lesson and now choose better blocks, but they have their limitations too I suppose.
Re: 543 440 Combo's
[Re: Al_Alguire]
#2782145
06/06/20 02:34 PM
06/06/20 02:34 PM
Al_Alguire
Las Vegas
My 470" tall deck went 9.69 at 139 in a 3100lb Duster with iron heads. It don't take a ton of power to run that in a typical A body racecar, 650ish will do it and I think they can live long happy lives at that level. Provided that the cylinders have some thickness or they have a tall fill.
Re: 543 440 Combo's
[Re: Dragula]
#2782278
06/06/20 10:31 PM
06/06/20 10:31 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I like it for a high torque low rpm build. I raced a 4.5 stroke 4.350 bore motor many years ago. Very mild build that made enough power to go 10.20s at 129 mph in a 3400 lb duster. I ran 4.10 gears and 33 inch tall slicks. Since the block has about a 650 hp fuse on it, plan accordingly. The best part is it can make decent power at VERY low rpm allowing a long valvetrain and block life if rpm is kept low.
Re: 543 440 Combo's
[Re: mopar dave]
#2782395
06/07/20 01:35 PM
06/07/20 01:35 PM
Al_Alguire
Las Vegas
That is a bunch of hp Al. What compression, cam and heads does it take to get 900hp? I say 900ish because it was never on a dyno, just a garage build but I know the car went 150 at 3470. It was 15.5-1, CFE ported B1 heads. Cam I am not sure I have the info any longer but I recall was low .800" lift for sure(common shaft T&D's, would have been a split lift deal), duration sure was high 280ish/290 ish and on a 114-117 lobe center. I am sure I have the build notes just not sure where as we are getting ready to move. It would be typical for other B1 stuff I have done over the years, this was a very nice set of heads done by CFE. The heads ended up on another combo and made 1025 in a 572. FWIW our 446 we ran in the dragster when my kid was a newbie was probably 650plus. Went 8.19 best here in Vegas at 1875lbs. Was a 12-1 compression deal with decent set of Indy -1's and a smallish roller on E85. Would have been in the 7's at sea level.
Re: 543 440 Combo's
#2782963
06/08/20 06:09 PM
06/08/20 06:09 PM
Posts: 741 Carson City, NV
440sourcedotcom
Carson City, NV
4.375 x 4.500 is 541.2 4.380 x 4.500 is 542.4 4.500 x 4.250 is 540.7 4.440 x 4.375 is 541.9 Our 543 kit is a 4.500 stroke x 4.380" bore, which equals 542.43 cubic inches. We offer pistons for that kit in .060" over, so we usually rate the cubic inches at the largest available bore size. And we did round up by .57 hundredths of a cubic inch.
Re: 543 440 Combo's
[Re: 440sourcedotcom]
#2782968
06/08/20 06:18 PM
06/08/20 06:18 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
4.375 x 4.500 is 541.2 4.380 x 4.500 is 542.4 4.500 x 4.250 is 540.7 4.440 x 4.375 is 541.9 Our 543 kit is a 4.500 stroke x 4.380" bore, which equals 542.43 cubic inches. We offer pistons for that kit in .060" over, so we usually rate the cubic inches at the largest available bore size. And we did round up by .57 hundredths of a cubic inch. Which block do you recommend? Any consideration on the industrial 413,block ? What’s the minimum wall thickness? Do you offer an assembled short block ?
