2006 cummins auto trans issues #2781829
06/05/20 06:04 PM
06/05/20 06:04 PM
Fairview Tennessee
SV_MOPARS Offline OP
Fairview Tennessee
my original owner 2006 diesel 4wd automatic with 131000 miles started acting up, when on a short trip to pick up something light maybe 1 1/2 ton plus light car trailer, the truck will not shift into second until it hits 2500 rpm now, no other issues except a slight shutter when coming to a stop, i baby this truck, about 40k ago i replaced the transducer and the govenor solenoid with the alison style, also put in an "extreme duty pressure solenoid manifold" at the same time, that all worked great until now, any ideas what could be wrong?
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2781887
06/05/20 08:30 PM
06/05/20 08:30 PM
Alberta
440_Offroader Offline
Alberta
Not really a transmission guy by any means, but maybe the torque converter is on its way out?
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2782004
06/06/20 08:43 AM
06/06/20 08:43 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
How’d the kick down band adjustment look when you had the pan down for the other goodies?
Re: 2006 cummins auto trans issues [Re: J_BODY] #2782065
06/06/20 11:40 AM
06/06/20 11:40 AM
Fairview Tennessee
Fairview Tennessee
honestly i cant remember its been so long, but i did adjust the bands then, i might try servicing the trans and replacing the transducer, govenor solenoid again and adjust the bands again, if that dont work i guess a rebuilt one from randy's transmission out of utah is in order, i really cant complain i bought the truck new 14 years ago and have had zero problems except for batteries and an ac compressor.
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2782074
06/06/20 12:01 PM
06/06/20 12:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Have you checked for codes?
Re: 2006 cummins auto trans issues [Re: John_Kunkel] #2782176
06/06/20 05:04 PM
06/06/20 05:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Probably 2nd gear band adjustment plus it is quick and easy without emptying the trans even. It is the only element applied in 2nd that comes on in 2nd that is not already on in 1st unless you are going from manual 1st. When the clearance gets big enough it takes longer to fill the servo and engage the band, tightening up the adjustment to compensate for wear reduces the distance the servo has to travel.
Re: 2006 cummins auto trans issues [Re: HotRodDave] #2782293
06/06/20 11:51 PM
06/06/20 11:51 PM
Fairview Tennessee
Fairview Tennessee
have not checked for codes yet, i dont have a check engine light on so i didn't think it would have a fault code, and the band adjustment makes sense so i will have to do that also, thanks for the replies you guys, i can always count on moparts for answers to most any issue!
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2782597
06/08/20 12:30 AM
06/08/20 12:30 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I was going to suggest the solenoid and transducer but you've already changed them. Might not hurt to pull them out and check for trash in the screens on them though it seems unlikely.
My 99 used to refuse to shift out of 1st unless you flashed it thru neutral, especially when it was cold. It got progressively worse. I just put up with it as I seldom used the truck. Sold it to someone that had big plans for it and wasn't concerned about it needing the solenoid etc.
Kevin
Re: 2006 cummins auto trans issues [Re: Twostick] #2782923
06/08/20 05:12 PM
06/08/20 05:12 PM
Fairview Tennessee
Fairview Tennessee
i adjusted the front band, test drove the truck, still holding first till it hits 2500 rpm then it will shift to second, it sure seems that the truck just does not have the power it used to, im thinkin the tranny is slipping or problems with the converter, i might just order the new tranny and be done with it.
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2783226
06/09/20 01:34 PM
06/09/20 01:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
still could be something outside the trans like the big KD solenoid motor thingy they added on in place of a cable not returning to low enough angle, could be bad TPS signal or a bunch of other things. Proper diagnosis is important here as you may spend $2000 on a trans and have the same issue when your done.
Re: 2006 cummins auto trans issues [Re: HotRodDave] #2783488
06/10/20 01:03 AM
06/10/20 01:03 AM
Fairview Tennessee
Fairview Tennessee
i wish it were only 2g's for a rebuilt 48re trans, its more like 3500 with converter, plus the new cooler, rear mainseal, rear freeze plug upgrade, shipping both ways for tranny and core return, labor, fluids comes to almost 7g's, i guess im gonna have to find somebody that i can trust to diagnose it.
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2783661
06/10/20 01:03 PM
06/10/20 01:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Drive it up here, spend a week fishing and I'll have it done with some basic upgrades for $2500. $7000 is insane!
Re: 2006 cummins auto trans issues [Re: HotRodDave] #2783790
06/10/20 05:04 PM
06/10/20 05:04 PM
Fairview Tennessee
Fairview Tennessee
thats one hell of an offer and i really appreciate it, but i have so much going on here, finishing the compound here for the daughters wedding in july which was postponed becuz of the scamdemic, will see what happens after, oh and i scanned the thing and got a fault code p-1753 which is some throttle sensor gadget, its going over to a trans guy who was recommended by a friend, thanks
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2783817
06/10/20 06:11 PM
06/10/20 06:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
TPS issues will cause the exact problem your having. Although its more common on gas motor trucks , but not unheard of on coal burners either
Re: 2006 cummins auto trans issues [Re: gtx6970] #2783826
06/10/20 06:41 PM
06/10/20 06:41 PM
A727Tflite Offline
A727Tflite  Offline
Get under the truck and you will find the TTVA - it’s a device that looks like a wiper motor. It is mounted vertical above the shift linkage and bolted to the side of the trans. It replaces the throttle pressure cable.
Have someone turn the ignition to run, but do not start it while you hold that TTVA. You should feel it energize.
Keep the key on for 60 seconds. The TTVA should go through a calibration procedure.
Shut the key off.
Then take it for s ride. See if that’s helps.
If the TTVA does not energize it may Ben stuck at wide open giving you late shifts.
You can remove the TTVA and take it for a ride - if it shifts earlier now, then that’s your problem.
Re: 2006 cummins auto trans issues [Re: A727Tflite] #2783833
06/10/20 07:14 PM
06/10/20 07:14 PM
Fairview Tennessee
Fairview Tennessee
thanks for the replies, i took it down to ron at trc trans in chatsworth after i scanned it and could not clear the p-1753 fault code for the tva problem, we took it for a ride with the scanner plugged in, he then cleared the code and now it's working perfectly, he said clean all the connections at the tva and any grounds and it should be fine, he would not take any money, i just purchased a brand new mopar one on ebay to have just in case the one in the truck gives me anymore grief, did not know it would throw a code without the truck having a check engine light on, damn computer controlled stuff really gets me frustrated sometimes, my 2013 freightliner with a detroit is even more frustrating, you guys are awesome, thanks for all the help
Re: 2006 cummins auto trans issues [Re: SV_MOPARS] #2783974
06/11/20 07:29 AM
06/11/20 07:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yeah the codes with no indicator light really sucks. GM put 3 turbos on one of our Duramax trucks at work. The driver complained of low power a couple of times. The dealer said it had turbo codes and changed the turbo under warranty. The truck I drive everyday got one turbo. We took it in with 95000 miles and asked them to check it out since it was almost out of warranty. They put 2 injectors and a turbo in it, no codes on my cheap scanner and no warning lights. That would have been 10K worth of work out of warranty!
68 Barracuda Formula S 340
