Front suspension/ steering box
#2781264
06/03/20 11:31 PM
06/03/20 11:31 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Driving my car today and it was sloppy. The suspension is fairly new but I have the same old steering box. I was wondering if I should get a steering box rebuild or flaming river or if there is a rack conversion I will look for other issues such as torsion bar preload and the ladder bars may not be neutral as this time Details. 68 roadrunner 3400 lbs Ladder bar suspension
Currently big block torsion bars and afco front shocks
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Front suspension/ steering box
[Re: MR_P_BODY]
#2781311
06/04/20 09:06 AM
06/04/20 09:06 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Thanks.
Cab. It is a 68 satellite Skinny tires in front Drag radials out back Ladder bars
I need double check the preload on the right ladder bar It might be pushing the car left
But I will check the items you guys suggested.
[Re: Kam*Kuda]
#2781940
06/05/20 10:31 PM
06/05/20 10:31 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Car looks amazing.
Thought I remembered it being supercharged or some such?
Ah, Probably got that wrong.....
You've been around off and on for a whole lot of years. Welcome back.
Rich H.
Esse Quam Videri
[Re: The Shadow]
#2782177
06/06/20 05:07 PM
06/06/20 05:07 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
You can try tightening the worm shaft if nothing else is loose Just go slow here. Tighten it a little and run it lock to lock with drag on the wheels. Tighten some more... When you feel a hard spot, back off to last known setting.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
