8 3/4 ID #2781015
06/03/20 11:06 AM
06/03/20 11:06 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Have an 8 3/4 housing with center section.
Its 56.5 inched wide so E body but cannot find anything on the CS ID.
Re: 8 3/4 ID [Re: MattW] #2781032
06/03/20 12:10 PM
06/03/20 12:10 PM
Locomotion Online content
Locomotion  Online Content
Best I can make out is 1634985, which is an earlier version of a 742 case.
moparts 8 3/4" tech archives
Re: 8 3/4 ID [Re: MattW] #2781065
06/03/20 01:49 PM
06/03/20 01:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
That is probably a early, pre 1961, big car, C body size rear end shruggy
Did you take it out of the housing? If so did it have tapered axles with threaded axle ends and nuts holding the brake drums on? If so it is pre 1965 up
Re: 8 3/4 ID [Re: Locomotion] #2781066
06/03/20 01:52 PM
06/03/20 01:52 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Good to know.
Well its not the small pinion.
Guess i didn't look hard enough!!!
Thx
Re: 8 3/4 ID [Re: Cab_Burge] #2781069
06/03/20 01:54 PM
06/03/20 01:54 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
No i don't think so.
I believe it has the regular adjusters.
Re: 8 3/4 ID [Re: MattW] #2781094
06/03/20 02:52 PM
06/03/20 02:52 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Could also be a '65-'69 C-body. Difference is the pinion angle.
