Re: Tow Dolly. Do I need to disconnect the driveshaft?
[Re: AARCONV]
#278086
04/05/09 12:47 PM
04/05/09 12:47 PM
manual trans is ok...automatics will be a problem in a long haul
Did you just guess up that answer or do you really know what you're talking about?
MOST if not ALL older stick transmissions CAN NOT be towed for very far in neutral, because the mainshaft will rotate inside the gears, and there's nothing to distribute oil
I understand that some "newer stuff" with overdrive geared transmissions "may" be OK DEPENDING on th vehicle.
Get ahold of Chrysler, take a trip through your owner's manual, or get ahold of someone in "Sams Club"
You need to find this answer specifically to the Dakota, not generally
#278087
04/05/09 01:01 PM
04/05/09 01:01 PM
Posts: 15,487 Florida
scratchnfotraction
with 440sixpack,turns with no lubrecation on the manual trannys I would R&R the shaft to be on the safe side IMO not to mentin the speedo is racking the miles that are not on the engine...the speedo will be running as its towed with the shaft in how long will it really take,you can just unhook from the rear axle and hang it with a good zip tie or wire and tape the u-joint caps on and ride done that a lot my self towing..with a dolly or a strap you could haul it with the rear on the dolly and leave the steering unlocked so it can turn..they ride right behind the tow car and the one be towed will follow...like a tram train done it that way a lot also
#278088
04/05/09 01:03 PM
04/05/09 01:03 PM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
Well spoken! I did have to take a look in my '72 manual, because I might have knee-jerk replied manual OK, auto disconnect driveshaft.
Sho' Nuff'... tow more than 15 miles or faster than 30 mph, driveshaft has to be disconnected; no distinction made between auto and manual for '72 Imperial Chrysler Plymouth.
Point well-made above is the best source of info is the factory manual...
[Re: OA5599]
#278089
04/05/09 05:20 PM
04/05/09 05:20 PM
Posts: 101 Oregon
RoadRaceDart
Back the truck on the dolly and you'll be fine.
Joshua
[Re: pittsburghracer]
#278093
04/05/09 10:02 PM
04/05/09 10:02 PM
Posts: 101 Oregon
RoadRaceDart
If the steering is locked straight ahead and the steering isn't worn out to the point that the wheels wobble it will work fine. I used to pull my 240Z around this way because the spoiler was too low to drive the car on front first. You might want some weight in the back of the truck to help keep the dolly on the road, but it will work fine. Tow trucks drag cars and trucks backward all the time. If you're that worried about pulling it backward then pull the driveshaft. Don't forget to plug the trans so the lube stays in and dirt stays out.
Joshua
[Re: Magnumguy]
#278095
04/06/09 08:06 AM
04/06/09 08:06 AM
scratchnfotraction
when I pulled mine from the rear axle and left the steering locked it wanted to pull the tires off the dolly when turning when unlocked the front would steer itself around the corners I think the damage they are talking about is rack and pinion...it does spin it all the way lock to lock on the steering... it does spin and hit kinda hard on tne locks but I dont turn them very sharp unless I had to sounds like you need to pull the shaft and tow it fowards good luck and swing wide around turns,watch the bumper poles at the gas stations DAMHIK
[Re: Bull1tt]
#278097
04/06/09 09:15 AM
04/06/09 09:15 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
some of the u-haul dollys have a pivoting platform for the wheels to set on, to allow the dolly to turn around a corner before the back of the vehicle being towed gets there, and the vehicle on the dolly can pivot from left to right on top of the dolly...are all dolly's like this?
another issue i've seen with people towing backwards, with the steering unlocked, is that the vehicle being towed starts crabbing out sidways as the front wheels are loose and free to turn.
**Photobucket sucks**
[Re: 70Cuda383]
#278098
04/06/09 09:59 AM
04/06/09 09:59 AM
Posts: 4,503 NJ
440challenger
NJ
I had some REALLLLLLLLLLLLL hairball expereiences all in one day trying to tow a 71 chevelle Backwards on a tow dolly. on the interstate the front end would start dancing all over the place and i looked over and the car was next to my truck, drivers door! Felt like i was trying to steer a wild bull. The front end would start swaping like crazy. Last time i did that. Suprised you guys haven't had problems
[Re: 440challenger]
#278099
04/06/09 11:32 AM
04/06/09 11:32 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
save yourself any trouble, and forget the dolley. rent a car trailer from U Haul for $65, and get the whole truck off the ground.
1981 Dodge D150 360 auto
