Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2757222
03/29/20 12:39 PM
03/29/20 12:39 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
wow great job kid . so over the top . I love the color . you gave me a great idea for my front suspension brace . I will be bending up 1/4 inch and 1/8th inch plate tomorrow. I am splitting mine over 2 inches in the 1/4 and 1 inch in the door.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: sparcy] #2765605
04/18/20 05:41 PM
04/18/20 05:41 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Out of paint!
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger w/ 6.1L/A518/9"
1968 Charger Bomber 440/4spd
1968 Roadrunner w/ 6.1L/6 speed
2010 B5 Challenger SRT 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2765730
04/18/20 11:23 PM
04/18/20 11:23 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: DynoDave] #2768906
04/27/20 09:45 PM
04/27/20 09:45 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Wow, beautiful.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: CDN72SE] #2769055
04/28/20 10:39 AM
04/28/20 10:39 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Really coming along nicely! Keep up the great work.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: Airgrabber] #2769838
04/30/20 01:39 PM
04/30/20 01:39 PM
Akron, ohio
76orangewagon Offline
Akron, ohio
Stunning !!!!
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 76orangewagon] #2770682
05/03/20 08:28 AM
05/03/20 08:28 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thanks all!
The 6.1L engine and TR6060 transmission are mated and on the RMS K frame. The engine is a 50K mile factory built short block. I added an Arrington cam shaft and CNC ported heads. The intake manifold has also been ported. From the factory it was rated at 425hp. It should comfortably make 500hp.
Holley wiring harness added
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2771894
05/06/20 06:25 PM
05/06/20 06:25 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2772232
05/07/20 07:16 PM
05/07/20 07:16 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Looks good in there!
DynoDave
Member # 12304
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: DynoDave] #2772533
05/08/20 03:56 PM
05/08/20 03:56 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Looking forward to seeing this one on the road!
'63 Dodge 330
11.19 @ 121 mph
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: GY3] #2772768
05/09/20 08:59 AM
05/09/20 08:59 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Me too!!!!
Rear suspension is loaded! The axles are from DSS and they slipped right in.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2773555
05/11/20 02:04 PM
05/11/20 02:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow, that rear looks like it could have been original equipment! eek
'63 Dodge 330
11.19 @ 121 mph
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: GY3] #2775266
05/16/20 09:38 PM
05/16/20 09:38 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Matt really did a nice job!
I don't like the taxi cab clusters so I went with a rally dash and bought the Dakota Digital gauges for 68-70 Charger. I rooted through my parts stash and picked out my nice Charger panel switches and cluster bezel. The bezel was redyed and came out pretty nice
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2776801
05/21/20 04:10 PM
05/21/20 04:10 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Sitting on its own suspension! It will sit at least an inch lower all the way around.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2776806
05/21/20 04:22 PM
05/21/20 04:22 PM
Akron, ohio
Akron, ohio
I love seeing a quality build...That thing is awesome...great job.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 76orangewagon] #2780481
06/01/20 06:03 PM
06/01/20 06:03 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thanks!
Wiring and plumbing in progress...
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2780897
06/02/20 08:08 PM
06/02/20 08:08 PM
the great wet north
Superfreak Offline
Superfreak  Offline
the great wet north
Looks really great!
"Too much to do and not enough time to do it"
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: Superfreak] #2781320
06/04/20 08:42 AM
06/04/20 08:42 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Finally received the driveshaft a couple days ago. I was a little late ordering it. The axle shafts I ordered in March arrived about 3 weeks after ordering so I assumed the driveshaft would take about that long but when I called with the driveshaft dimensions, DSS said they were 8-9 weeks out on driveshafts.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2809278
08/15/20 02:36 PM
08/15/20 02:36 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Radiator is in...
The stainless and chrome trim finally all came back from the powdercoater.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2809329
08/15/20 08:59 PM
08/15/20 08:59 PM
Medford OR
FrankenScamp Offline
Medford OR
As much as I hate seeing blacked out grilles, this thing is AWESOME! And the grille looks great.
Chrome bumpers? Black? Body color? work
beer
Last edited by FrankenScamp; 08/15/20 09:03 PM. Reason: To make right, what once went wrong
