Bad PCV - hesitating secondaries ? #2780247
06/01/20 06:44 AM
06/01/20 06:44 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Cant find verification
If a pcv is sticking closed or improperly sized
Will it create issues with vacuum secondaries ?
Re: Bad PCV - hesitating secondaries ? [Re: sogtx] #2780285
06/01/20 09:35 AM
06/01/20 09:35 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Draw on the vacuum sec. comes from orifices in the barrel of the carb above the throttle plates, right at the venturi . A plugged or open PCV wouldn't have an effect on secondary opening.
Re: Bad PCV - hesitating secondaries ? [Re: B1MAXX] #2782820
06/08/20 02:30 PM
06/08/20 02:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats right as the vacuum secondaries work off venturi vacuum not manifold vacuum. Ron
Re: Bad PCV - hesitating secondaries ? [Re: sogtx] #2783181
06/09/20 12:07 PM
06/09/20 12:07 PM
AndyF Offline
AndyF  Offline
Just test it. Remove the PCV hose and plug it on the carb side and try it. Then you'll know.
