results of added compression to 511
#2780001
05/31/20 10:41 AM
05/31/20 10:41 AM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
As some may remember my post on added compression and the 1 point of compression not doing much but adding a few horsepower to my 511. Old compression 11.26:1 and my current compression 12.5:1. Results: old best with 11.26 was 1040@130 and new best with 12.5 is 10.06@134. There were a few other changes, but nothing that's worth much to the 4mph gain. I once again I will say compression is a big part of your combo and here's the proof.
Re: results of added compression to 511
[Re: justinp61]
#2780043
05/31/20 12:27 PM
05/31/20 12:27 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Nice. Enough MPH to get into the 9’s pretty easily What track were you at?
[Re: mopar dave]
#2780065
05/31/20 01:05 PM
05/31/20 01:05 PM
Thumperdart
State of confusion
I said it all along that your combo was off in a BIG way and now you proved it......Congrats and the t-ram will add more trust me....
[Re: mopar dave]
#2780085
05/31/20 02:34 PM
05/31/20 02:34 PM
B3422W5
Portage,michigan
Thanks guys. The best its ever launched and ran. I was really happy yesterday, that doesn't happen at the track too often. I'll say it again, compression compression compression, especially with these MW Victor heads. They need compression to flow properly, why, I don't know. Something not right with the ports is my guess. I was at Mid Michigan and the track was prepped real good. Never spun the radials except one pass and it was my fault. I foot braked and left at 2500 every pass. I set the shift lite at 6600 and anything more slowed it down a bit. Only made carb adjustments and shock adjustments. I was crossing with 12.8-13.0 on the AF meter. Only carb adjust I made was to the HSB. The .030 were faster than the .028 for sure. I was pulling big wheelies( 1ft) so I thighten the front rebound 1 click on the Vikings and got it down to what you see in the vid. It may be worth some ET to tighten one more click. I left the Caltrac shocks on 5 the whole time because the radials were dead hooking. Thanks for the awesome carb Dom. I'll post the inside gopro vid when I get it loaded. Personally, i think the camshaft was way to big for the previous compression. Has a tendency to make everything lazy. The extra compression has made everything work together much better. Just my opinion. Regards the wheelies, one foot isnt much with a leafspring car at all. But i agree, if you can continue to hit the tire enough to make it stick, by tightening up the front, abd get away with it... great job. you may see that not work on a more marginal track
[Re: mopar dave]
#2780092
05/31/20 03:37 PM
05/31/20 03:37 PM
Posts: 4,213 New York
polyspheric
New York
Smaller chamber increases intake vacuum and makes pressure changes during overlap more rapid: all good.
Boffin Emeritus
[Re: mopar dave]
#2780093
05/31/20 03:38 PM
05/31/20 03:38 PM
Posts: 4,457 Washington
madscientist
Washington
Thanks guys. The best its ever launched and ran. I was really happy yesterday, that doesn't happen at the track too often. I'll say it again, compression compression compression, especially with these MW Victor heads. They need compression to flow properly, why, I don't know. Something not right with the ports is my guess. I was at Mid Michigan and the track was prepped real good. Never spun the radials except one pass and it was my fault. I foot braked and left at 2500 every pass. I set the shift lite at 6600 and anything more slowed it down a bit. Only made carb adjustments and shock adjustments. I was crossing with 12.8-13.0 on the AF meter. Only carb adjust I made was to the HSB. The .030 were faster than the .028 for sure. I was pulling big wheelies( 1ft) so I thighten the front rebound 1 click on the Vikings and got it down to what you see in the vid. It may be worth some ET to tighten one more click. I left the Caltrac shocks on 5 the whole time because the radials were dead hooking. Thanks for the awesome carb Dom. I'll post the inside gopro vid when I get it loaded. It’s not just those heads that like compression. They ALL like compression, even on pump gas IF you do it right. Building anything for pump gas under 11:1 is leaving a lot on the table.
[Re: Thumperdart]
#2780107
05/31/20 05:01 PM
05/31/20 05:01 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I said it all along that your combo was off in a BIG way and now you proved it......Congrats and the t-ram will add more trust me.... the right tunnelram will require a chassis cert and a license gauranteed. If you find one of the older designs porting may be needed for best results.
[Re: gregsdart]
#2780117
05/31/20 05:29 PM
05/31/20 05:29 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
that's great result . thanks for the feedback .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Cab_Burge]
#2780158
05/31/20 07:26 PM
05/31/20 07:26 PM
Posts: 1,030 ohio
67mprfan
ohio
I think the glove box door being open helped with wind drag ....nice outing and congrats on the new best
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: mopar dave]
#2780164
05/31/20 08:04 PM
05/31/20 08:04 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I have asked before but I forgot, what is the race weight ?
