Page 1 of 3 1 2 3
results of added compression to 511 #2780001
05/31/20 10:41 AM
05/31/20 10:41 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
As some may remember my post on added compression and the 1 point of compression not doing much but adding a few horsepower to my 511. Old compression 11.26:1 and my current compression 12.5:1. Results: old best with 11.26 was 1040@130 and new best with 12.5 is 10.06@134. There were a few other changes, but nothing that's worth much to the 4mph gain. I once again I will say compression is a big part of your combo and here's the proof.
Re: results of added compression to 511 [Re: mopar dave] #2780008
05/31/20 10:55 AM
05/31/20 10:55 AM
Mt Morris Michigan
Mt Morris Michigan
Re: results of added compression to 511 [Re: mopar dave] #2780012
05/31/20 11:13 AM
05/31/20 11:13 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Great job and results!
Re: results of added compression to 511 [Re: mopar dave] #2780014
05/31/20 11:18 AM
05/31/20 11:18 AM
tboomer Online work
tboomer  Online Work
Congrats Dave! Work on that 60'...It has some more in it! Ted wave
Re: results of added compression to 511 [Re: mopar dave] #2780039
05/31/20 12:17 PM
05/31/20 12:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Nice pick up everywhere. Foot braking?
Re: results of added compression to 511 [Re: justinp61] #2780043
05/31/20 12:27 PM
05/31/20 12:27 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Nice.
Enough MPH to get into the 9’s pretty easily
What track were you at?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: results of added compression to 511 [Re: mopar dave] #2780065
05/31/20 01:05 PM
05/31/20 01:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I said it all along that your combo was off in a BIG way and now you proved it......Congrats and the t-ram will add more trust me....
Re: results of added compression to 511 [Re: Thumperdart] #2780081
05/31/20 02:00 PM
05/31/20 02:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice! Great looking car
68 Barracuda Formula S 340
Re: results of added compression to 511 [Re: mopar dave] #2780082
05/31/20 02:10 PM
05/31/20 02:10 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks guys. The best its ever launched and ran. I was really happy yesterday, that doesn't happen at the track too often. I'll say it again, compression compression compression, especially with these MW Victor heads. They need compression to flow properly, why, I don't know. Something not right with the ports is my guess. I was at Mid Michigan and the track was prepped real good. Never spun the radials except one pass and it was my fault. I foot braked and left at 2500 every pass. I set the shift lite at 6600 and anything more slowed it down a bit. Only made carb adjustments and shock adjustments. I was crossing with 12.8-13.0 on the AF meter. Only carb adjust I made was to the HSB. The .030 were faster than the .028 for sure. I was pulling big wheelies( 1ft) so I thighten the front rebound 1 click on the Vikings and got it down to what you see in the vid. It may be worth some ET to tighten one more click. I left the Caltrac shocks on 5 the whole time because the radials were dead hooking. Thanks for the awesome carb Dom. I'll post the inside gopro vid when I get it loaded.
Re: results of added compression to 511 [Re: mopar dave] #2780085
05/31/20 02:34 PM
05/31/20 02:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Personally, i think the camshaft was way to big for the previous compression. Has a tendency to make everything lazy.
The extra compression has made everything work together much better.
Just my opinion.
Regards the wheelies, one foot isnt much with a leafspring car at all. But i agree, if you can continue to hit the tire enough to make it stick, by tightening up the front, abd get away with it... great job. you may see that not work on a more marginal track
1.41 best 60 foot
6.60 at 103.90 1/8
Re: results of added compression to 511 [Re: mopar dave] #2780092
05/31/20 03:37 PM
05/31/20 03:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Smaller chamber increases intake vacuum and makes pressure changes during overlap more rapid: all good.
Boffin Emeritus
Re: results of added compression to 511 [Re: mopar dave] #2780093
05/31/20 03:38 PM
05/31/20 03:38 PM
Washington
madscientist Offline
Washington
It’s not just those heads that like compression. They ALL like compression, even on pump gas IF you do it right. Building anything for pump gas under 11:1 is leaving a lot on the table.
Re: results of added compression to 511 [Re: B3422W5] #2780094
05/31/20 03:41 PM
05/31/20 03:41 PM
Mt Morris Michigan
Mt Morris Michigan
I agree 100% Don. Too low of compression for the cam and the heads. Compression coaxes the air thru the head and the higher it is the faster the air movement and these heads need all the help they can get IMO. Here's another vid. I was almost out of gas, had about 1.5 gallons left. The gauge reads E and the pressure gauge reads low pressure after heating the tires. Had to wait for fuel pressure before I could stage and shut the pump off at the end of the track to save the pump. https://youtu.be/rScO2Oa34qY
Re: results of added compression to 511 [Re: Thumperdart] #2780107
05/31/20 05:01 PM
05/31/20 05:01 PM
gregsdart Offline
gregsdart  Offline
the right tunnelram will require a chassis cert and a license gauranteed. If you find one of the older designs porting may be needed for best results.
Re: results of added compression to 511 [Re: gregsdart] #2780117
05/31/20 05:29 PM
05/31/20 05:29 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
that's great result . thanks for the feedback .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: results of added compression to 511 [Re: mopar dave] #2780133
05/31/20 06:36 PM
05/31/20 06:36 PM
You got a lot of bang for your work and investment up bow
I've raise the compression on my old M.W. stocker form 10.8 to 11.5 to 1 and didn't see anywhere near those results whiney
My old pump gas Duster responded differently though, it liked all the changes I made to it boogie
Re: results of added compression to 511 [Re: Cab_Burge] #2780158
05/31/20 07:26 PM
05/31/20 07:26 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I think the glove box door being open helped with wind drag ....nice outing and congrats on the new best
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: results of added compression to 511 [Re: Cab_Burge] #2780162
05/31/20 08:00 PM
05/31/20 08:00 PM
Mt Morris Michigan
Mt Morris Michigan
Cab, I did all the reseach I could about these under performing heads and what I noticed was they need 12:1 minimum compression to perform well. Anyone running these heads with less than that were not getting good results IMO. I don't know what Edelbrock did with these ports, but i'm thinking there shaped wrong. I know Dwayne said the valve is almost the same size as the port throat under it. I think the Indy tunnel ram with the Thumper 750's will easily put me into the 9's. Then a cam change to something more aggressive and maybe 9.80's or better? I could have run it with the air clearer or the 4 hole tapered spacer and busted into the 9's, but I ran out of fuel. I can't believe 7 or 8 gallons of fuel was used in 6 passes. Where did all that fuel go? Thought I had plenty, but it cut my day short.
Re: results of added compression to 511 [Re: mopar dave] #2780164
05/31/20 08:04 PM
05/31/20 08:04 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have asked before but I forgot, what is the race weight ?
Re: results of added compression to 511 [Re: 67mprfan] #2780165
05/31/20 08:05 PM
05/31/20 08:05 PM
Mt Morris Michigan
Mt Morris Michigan
yeah, for sure. If I don't open it, it will open itself on launch. One other thing I did was report the Indy intake. Forgot about that.
Page 1 of 3 1 2 3
