Does anyone rechrome oem tail pipes or are they garbage? #2779826
05/30/20 05:49 PM
05/30/20 05:49 PM
IL
furious70 Offline OP
IL
I've got a b body set that won't clean up, do people rechrome or pitch?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: furious70] #2779959
05/31/20 08:27 AM
05/31/20 08:27 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi 70 , the whole tail pipe , or your tail pipe TIPS ? help drive
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: 1969ronnie] #2779966
05/31/20 09:04 AM
05/31/20 09:04 AM
IL
IL
Just the tips, sorry.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: furious70] #2779978
05/31/20 09:36 AM
05/31/20 09:36 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I doubt you could get them rechromed for what you could replace them for. Unless this is a concours restoration, I'd look up Pypes and get their stainless ones. They're available in different pipe sizes too so you aren't stuck with the anemic factory tailpipe size. I had a set in 2.5" that I got at Carlisle for about $100.
Kevin
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: Twostick] #2779984
05/31/20 09:42 AM
05/31/20 09:42 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
We found 3" stainless for our Charger, great finish, as good as or better than new OE
Don't know what brand, bought from a poster here, I think.
Joe
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: furious70] #2779993
05/31/20 10:16 AM
05/31/20 10:16 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
pitch them, go with stainless, you'll be glad you did...I wish I had the first time rather than waste my money on NOS, that started pitting after just a few years
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: DAYCLONA] #2780108
05/31/20 05:02 PM
05/31/20 05:02 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Get polished stainless. Upkeep is much easier!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: hemi-itis] #2780192
05/31/20 09:07 PM
05/31/20 09:07 PM
BDW Offline
BDW  Offline
I got the Pypes tips for a great price, only complaint was I had to polish off the logo etchings they put on them.
They still look great 3 years later.
Pic before polishing
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: BDW] #2780200
05/31/20 09:42 PM
05/31/20 09:42 PM
GA
roadrunninMark Offline
GA
If you are gonna toss them, can you sandblast and then try that chrome spray paint or even that new "chroming process", like where they chrome a water bottle? Like this --> https://www.youtube.com/watch?v=c9-wFTUhpT4
Re: Does anyone rechrome oem tail pipes or are they garbage? [Re: roadrunninMark] #2780226
06/01/20 12:05 AM
06/01/20 12:05 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
OEM tips were liable to came apart in a few years after they were improperly made. The hanger bracket should have been seal welded to the body of the tip, but it wasn't. Not seal welding allowed the acid used in plating to be retained in the interface between the hanger and the main body. The result was the retained acid in time destroyed the hanger, and the rear of the exhaust system fell down on the rear axle. This is exactly what happened to my '69 Barracuda on a road trip about 1500 miles from home in about 1971 or 1972 when I was driving from Houston to Portland, OR. I replaced the failed tip with a parts counter one to get the exhaust pipe off the rear axle. This parts counter tip and the other original one lasted over 50 years, so my personal failure rate was 1 out of 3.
Re-chroming survivors will create the same problem all over again with the new plating acid if the hanger is not seal welded. Most platers would probably tell you to get it seal welded and then they could plate it. Note that to do a proper seal weld all around the hanger, welding needs to be done INSIDE the tip...
I tossed my originals and bought stainless reproductions.
