Attaching door glass edge trim - help needed #2779929
05/31/20 01:13 AM
05/31/20 01:13 AM
Garland, Texas
1badmopar Offline OP
Garland, Texas
The vertical stainless door glass trim edgeing recently popped off and I’m not sure what adhesive to use to reattach it? This is on a 1966 Belvedere 2 door hardtop. Any help would be appreciated!
Bridger
1966 Plymouth Belvedere
520" RB w/ Indy 440-1 Heads
FiTech Fuel Injection
TKO 600 conversion
[img]https://flic.kr/p/2j1ejsK[/img]
Re: Attaching door glass edge trim - help needed [Re: 1badmopar] #2779957
05/31/20 08:17 AM
05/31/20 08:17 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I used butyl tape on mine. Work it to thin it then place over the glass then fit your trim piece until it fit snugly . I got mine from a local glass place they gave me 2 rolls.
Re: Attaching door glass edge trim - help needed [Re: hemirdrnnr] #2780102
05/31/20 04:42 PM
05/31/20 04:42 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Butyl tape is a good idea.You can also use urethane sealer. twocents
Re: Attaching door glass edge trim - help needed [Re: 1badmopar] #2780150
05/31/20 07:06 PM
05/31/20 07:06 PM
Garland, Texas
Garland, Texas
Thanks for the help! Exactly what I needed. I’ll give it a try.
TKO 600 conversion
Re: Attaching door glass edge trim - help needed [Re: 1badmopar] #2780170
05/31/20 08:18 PM
05/31/20 08:18 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I used clear silicon sealer to put the chrome strips back on my Dart's windows. You could use black also.
Re: Attaching door glass edge trim - help needed [Re: 70HemiGTX] #2780765
06/02/20 03:07 PM
06/02/20 03:07 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Attaching door glass edge trim - help needed [Re: 71TA] #2780805
06/02/20 04:32 PM
06/02/20 04:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You show that "tape" being used to hold the vent window to the lower chrome piece. The original question was in regards to the vertical 1/4 glass stainless. Does the stuff you linked to work for that application as well or does it take a different thickness?
Edit: Just needed to read a little further. thumbs I need two kits(4 pieces) for my Dart. I'll hit you up if you are going to the Mopar Nats.(if they have it this year)
Quote
Also used to hold the chrome trim on on the rear edge of the door glass or the front edge of the quarter glass.
Re: Attaching door glass edge trim - help needed [Re: burdar] #2780822
06/02/20 05:39 PM
06/02/20 05:39 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Agreed, originally it was tape on both the back edge vertical trim as well as the vent wing glass.
Ive tried to use it resetting vent wing glass , Had ZERO luck making it work .
went with the butyl in a tube and trimmed off the excess . and never looked back
Re: Attaching door glass edge trim - help needed [Re: 71TA] #2780885
06/02/20 08:21 PM
06/02/20 08:21 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Originally Posted by 71TA
That stuff looks great!
