Drive Shaft ??? #2779805
05/30/20 04:39 PM
05/30/20 04:39 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Hey Guys I got my new Strange S60 rear end mounted and fitted in my car. I wanted to ask generally how much shorter Driveshaft do you need changing from a 8.75 to a dana ? I keep getting around 1" difference but don't want to make a mistake when ordering a new one. Thanks , " side note my new Dana looks Badazz under my car. " LOL
6.50 @105.26
Re: Drive Shaft ??? [Re: Kindafast] #2779825
05/30/20 05:43 PM
05/30/20 05:43 PM
AndyF Offline
AndyF  Offline
Since you have the rear end in the car why not just use a tape measure to tell you how long the driveshaft should be?
Re: Drive Shaft ??? [Re: AndyF] #2779837
05/30/20 06:58 PM
05/30/20 06:58 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Or put the old shaft in, bottom it into the trans, and measure the diff end.
Just be sure to allow for the new shaft to NOT bottom out in the trans.
Re: Drive Shaft ??? [Re: topside] #2779841
05/30/20 07:05 PM
05/30/20 07:05 PM
Seaford, Va
Seaford, Va
I did and it came up with about an inch difference , but was just wondering if anybody had ever had an exact number from Mopar .
6.50 @105.26
Re: Drive Shaft ??? [Re: Kindafast] #2779845
05/30/20 07:11 PM
05/30/20 07:11 PM
AndyF Offline
AndyF  Offline
I'd believe the tape measure over any information sourced from the internet.
Re: Drive Shaft ??? [Re: AndyF] #2779852
05/30/20 07:29 PM
05/30/20 07:29 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Go to Doctordiff's website or Strange's site and measure like they say and it will come out perfect. They both have a great deal on a CM drive shaft that will fit perfect and not break the bank.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Drive Shaft ??? [Re: fourgearsavoy] #2779869
05/30/20 08:09 PM
05/30/20 08:09 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Gus beer
Do exactly this....I just did and Cass gets you the right one based on you taking two easy measurements. Length of the trans output shaft and the face of the trans to the face of the yoke. Easy and done... 1 week later you’re installing it.
Re: Drive Shaft ??? [Re: Suregrip391] #2779905
05/30/20 10:51 PM
05/30/20 10:51 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
1.22 inches...
Tony
70 AARCuda Vitamin C
Re: Drive Shaft ??? [Re: 70AARcuda] #2779917
05/30/20 11:56 PM
05/30/20 11:56 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Measure it.
Twice.
Re: Drive Shaft ??? [Re: tubtar] #2779926
05/31/20 12:37 AM
05/31/20 12:37 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
changed out 3 cars from 8 3/4 to Strange D60s.....
Tony
Re: Drive Shaft ??? [Re: 70AARcuda] #2779946
05/31/20 06:45 AM
05/31/20 06:45 AM
Seaford, Va
Seaford, Va
Originally Posted by 70AARcuda
1.22 inches...
Thanks my friend. That is the general measurement I am getting also. I just wanted others input.
6.50 @105.26
Re: Drive Shaft ??? [Re: Kindafast] #2780053
05/31/20 12:43 PM
05/31/20 12:43 PM
I measure for driveshaft length(center to center) by putting a tranny yoke exactly like I'm going to be using and shove it in the tranny all the way and pull it out 3/4inch and then measure from the center of the U joint holes in both the tranny and pinion yoke with the cars weight on the wheels or up on jack stands so the suspension is loaded like it will be on the ground up scope
Re: Drive Shaft ??? [Re: Cab_Burge] #2780060
05/31/20 01:00 PM
05/31/20 01:00 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I ordered a CM shaft w. billet trans yoke from Strange and used their measuring guidelines. Been a few years, but the price for everything was reasonable...well, back then.
https://www.strangeengineering.net/forms/driveshaft-order-form/
If you plan on using the same yoke....
""DRIVESHAFT ONLY – NO TRANSMISSION YOKE: Push the transmission yoke all the way in until it bottoms, pull it out 7/8” and measure center to center. This is the ”C” dimension. If you are not using all 1350 series yokes, supply the “D” and “E” from any that are not and note which end they belong.* Your transmission yoke will need to be sent-in to properly balance the driveshaft.""
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Drive Shaft ??? [Re: Kindafast] #2780901
06/02/20 09:29 PM
06/02/20 09:29 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
