Drive Shaft ???
#2779805
05/30/20 04:39 PM
05/30/20 04:39 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey Guys I got my new Strange S60 rear end mounted and fitted in my car. I wanted to ask generally how much shorter Driveshaft do you need changing from a 8.75 to a dana ? I keep getting around 1" difference but don't want to make a mistake when ordering a new one. Thanks , " side note my new Dana looks Badazz under my car. " LOL
6.50 @105.26
Re: Drive Shaft ???
[Re: topside]
#2779841
05/30/20 07:05 PM
05/30/20 07:05 PM
Kindafast
Seaford, Va
I did and it came up with about an inch difference , but was just wondering if anybody had ever had an exact number from Mopar .
6.50 @105.26
Re: Drive Shaft ???
[Re: Kindafast]
#2779845
05/30/20 07:11 PM
05/30/20 07:11 PM
Posts: 31,083 Oregon
AndyF
I did and it came up with about an inch difference , but was just wondering if anybody had ever had an exact number from Mopar . I'd believe the tape measure over any information sourced from the internet.
Re: Drive Shaft ???
[Re: AndyF]
#2779852
05/30/20 07:29 PM
05/30/20 07:29 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Go to Doctordiff's website or Strange's site and measure like they say and it will come out perfect. They both have a great deal on a CM drive shaft that will fit perfect and not break the bank. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Drive Shaft ???
[Re: fourgearsavoy]
#2779869
05/30/20 08:09 PM
05/30/20 08:09 PM
Posts: 1,978 USA
Suregrip391
USA
Go to Doctordiff's website or Strange's site and measure like they say and it will come out perfect. They both have a great deal on a CM drive shaft that will fit perfect and not break the bank. Gus Do exactly this....I just did and Cass gets you the right one based on you taking two easy measurements. Length of the trans output shaft and the face of the trans to the face of the yoke. Easy and done... 1 week later you’re installing it.
Re: Drive Shaft ???
[Re: tubtar]
#2779926
05/31/20 12:37 AM
05/31/20 12:37 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
changed out 3 cars from 8 3/4 to Strange D60s.....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Drive Shaft ???
[Re: 70AARcuda]
#2779946
05/31/20 06:45 AM
05/31/20 06:45 AM
Kindafast
Seaford, Va
Thanks my friend. That is the general measurement I am getting also. I just wanted others input.
6.50 @105.26
Re: Drive Shaft ???
[Re: Cab_Burge]
#2780060
05/31/20 01:00 PM
05/31/20 01:00 PM
Posts: 1,229 In The Hills
jughed
In The Hills
I ordered a CM shaft w. billet trans yoke from Strange and used their measuring guidelines. Been a few years, but the price for everything was reasonable...well, back then. https://www.strangeengineering.net/forms/driveshaft-order-form/If you plan on using the same yoke.... ""DRIVESHAFT ONLY – NO TRANSMISSION YOKE: Push the transmission yoke all the way in until it bottoms, pull it out 7/8” and measure center to center. This is the ”C” dimension. If you are not using all 1350 series yokes, supply the “D” and “E” from any that are not and note which end they belong.* Your transmission yoke will need to be sent-in to properly balance the driveshaft.""
