Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: TH400 to RB in 69 b body info [Re: Clanton] #2774983
05/15/20 09:40 PM
05/15/20 09:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hope I can get this pic sized and loaded. It bolts to the crank flange and the dial indicator clamps in the slit.
64 Plymouth Savoy
Dana 60
Re: TH400 to RB in 69 b body info [Re: Clanton] #2775019
05/16/20 02:44 AM
05/16/20 02:44 AM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by Clanton
So with .014 offset I will have to adjust all the bolt holes on the bell.What say you?
I haven't had to enlarge any of the bolt holes in the scatter shields I've corrected shruggy
Do yours first and see before fixing what may not be broken scope work
Re: TH400 to RB in 69 b body info [Re: fourgearsavoy] #2775053
05/16/20 09:32 AM
05/16/20 09:32 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Wow nice job on that fixture!I was thinking a bridge over the crank bolted in the converter holes with a post like yours.
Re: TH400 to RB in 69 b body info [Re: Cab_Burge] #2775054
05/16/20 09:35 AM
05/16/20 09:35 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Cab I will not adjust any holes until I am sure it needs it.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2778103
05/25/20 04:01 PM
05/25/20 04:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I was dreading cutting the trans tunnel frame and this is all I was comfortable cutting out to this point with an opening about 5 1/2".The only way I know to cut the flat lip is with a saw blade without the frame to hold it.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2778107
05/25/20 04:11 PM
05/25/20 04:11 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I flattened the lip with a 2lb hammer just fine
Re: TH400 to RB in 69 b body info [Re: Clanton] #2778152
05/25/20 07:39 PM
05/25/20 07:39 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
The lip doesnt need flattening
You need to cut vertically on the tunnel brace
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2778189
05/25/20 09:41 PM
05/25/20 09:41 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Where I cut is where it is now.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2778464
05/26/20 06:51 PM
05/26/20 06:51 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I guess I installed it wrong in my car
Keep posting so I can see what I did wrong
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2778474
05/26/20 07:10 PM
05/26/20 07:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I did jump the gun as far as waiting for my trans to see what it needed.I hope to have my trans the end of next week.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2779167
05/28/20 05:33 PM
05/28/20 05:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Dialing in the bell with offset dowels can be exhausting if you never did it.I got within .020 with .000 on 1 side to start.I will try again tomorrow.
I had to remove the bolts holding the bell to the engine on the lowest 2 boltsto allow the dowels to move the bell a couple of times and check other bolts.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2779736
05/30/20 12:56 PM
05/30/20 12:56 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Try brushing up on cosine indicator effect.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2779749
05/30/20 01:19 PM
05/30/20 01:19 PM
Welcome to the world of frustrations on race cars and such whistling grin
Your within .010 from perfect so stick with it and shoot for ,003 to .007 max run out up wrench
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2779763
05/30/20 01:36 PM
05/30/20 01:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I know I need to get the dial at a better angle.I also have the dowel at max lift and will work on the last .005ps:I got it down to .013 at 2 oclock and .000 at 8 oclock and I am wondering if I can go with a .020 dowel and get it down to just a few thou.What do you think?
Re: TH400 to RB in 69 b body info [Re: Clanton] #2779965
05/31/20 08:50 AM
05/31/20 08:50 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I need some help deciding to got a .020 dowel set.I got it down to .013 at 2 oclock and .000 at 8 oclock and I am wondering if I can go with a .020 dowel and get it down to just a few thou.What do you think?dowel set .021 at this time I have 3 bolts that will not thread and are hitting the hole in the 2 lower block holes and 1 on the upper holes.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2780059
05/31/20 12:57 PM
05/31/20 12:57 PM
Are you moving the offset dowels towards the crankshaft to help move remove the run out?
Re: TH400 to RB in 69 b body info [Re: Cab_Burge] #2780067
05/31/20 01:14 PM
05/31/20 01:14 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The dowels are facing to the top of the bell with a few less thou on the top side now
Re: TH400 to RB in 69 b body info [Re: Clanton] #2780075
05/31/20 01:41 PM
05/31/20 01:41 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
if I had .005 more on the dowel[.021"] the next size I would be there with the dowels like it is now.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2780135
05/31/20 06:39 PM
05/31/20 06:39 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
If those numbers are correct the hole isnt round.
Take readings at 12, 3,6 and ,9. Ignore the rest
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2780140
05/31/20 06:46 PM
05/31/20 06:46 PM
What he is seeing is very common, it depends on where you locate the zero on the dial indictor to start with
I now start with the zero at 12 o clock and go from there up
If it is oblong, goes to +.012 and then returns to zero and then goes to -.017 and then returns to zero at 12 o clock I know where and what size offset bushing to start with shruggy
It ain't easy but it is doable up wrench grin
