A body power brake master cylinder #2779040
05/28/20 12:02 PM
05/28/20 12:02 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
I am in need of a master cylinder for my 69 Dart. It has power disc brakes (converted from drum). I have found several numbers, but no one seems to have it in stock. I looked on E-bay and there are a couple with pictures, but they say they might send one that will work, but not look correct, which I don't want. Any idea on getting one? Will one from a 71-76 A body work? Thanks. Aaron.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: A body power brake master cylinder [Re: Prodart440] #2779075
05/28/20 01:19 PM
05/28/20 01:19 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Bore size is smaller on the later ones. 0.937" vs 1.00". It will work, but you'll have a bit longer pedal travel.
Re: A body power brake master cylinder [Re: Sniper] #2779088
05/28/20 02:02 PM
05/28/20 02:02 PM
Avondale AZ
Avondale AZ
Just longer travel? It won't affect the hardness of the pedal?
Aaron
68 Coronet 440
Re: A body power brake master cylinder [Re: Prodart440] #2779136
05/28/20 03:47 PM
05/28/20 03:47 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
With power brakes you probably won't notice it, but it should be a bit softer.
Re: A body power brake master cylinder [Re: Sniper] #2779144
05/28/20 04:13 PM
05/28/20 04:13 PM
Avondale AZ
Avondale AZ
Awesome! Thanks! I just ordered one!
Aaron
68 Coronet 440
