Page 2 of 3 1 2 3
Re: Bleeding Brakes, without a helper [Re: BDW] #2778501
05/26/20 08:34 PM
05/26/20 08:34 PM
Guitar Jones Offline
Originally Posted by BDW
Do you need to submerge the drain hose in fluid for the gravity method?
No, in fact you don't even need a hose.
Re: Bleeding Brakes, without a helper [Re: Guitar Jones] #2778527
05/26/20 09:34 PM
05/26/20 09:34 PM
Gravity works as long as the master cylinder is higher than the bleeder valves up
It won't work on my race car, 1970 Cuda tube chassis car or my 1940 ford, pressure or suction only on them due to the master cylinders being lower than the bleeder valves shruggy
Re: Bleeding Brakes, without a helper [Re: mopar97] #2778544
05/26/20 10:29 PM
05/26/20 10:29 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Originally Posted by mopar97
Several things that have worked for me.
Gravity bleed does work. Nut unless you want a mess to clean up later, slip a hose over the nipple and into a bottle.
Use a metal oil can to fill the lines with fluid from the bleeder end.
You can also use an old brake fluid bottle 1/2 full with a hose. Loosen the bleeder screw on the wheel in question, slide the hose over the nipple and insert into the fluid. Pump the brake pedal 10-12 times. This way you are pulling fluid from 1 end and pushing from the other. Do each wheel and then check your pedal. Make certain the bottle has fluid in it or you will be pulling air into the system.
In every case the master cylinder was hardest to bleed. If I can I will bench bleed it.
By doing this, aren't you pushing old fluid into new fluid? Mixing the fluid?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Bleeding Brakes, without a helper [Re: 70sixpkrt] #2778587
05/27/20 06:47 AM
05/27/20 06:47 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
you can buy something similar to the speed bleeders at the parts store.i
it's a rubber line with a check valve.
hose with check valve
works on the same principal as the hose in a bottle of fluid stopping the air from flowing back into the line when the pedal is released.
perception is 90% of reality
Re: Bleeding Brakes, without a helper [Re: Mr T2U] #2778603
05/27/20 08:48 AM
05/27/20 08:48 AM
RWG75
RWG75
My helper is usually a 2x4. Pump the brake peddle with the bleeders closed - like your the second body. Wedge the lumber between the brake pedal and the seat frame to hold the pedal down. Crack a bleeder, repeat until no air, move on to next wheel. The only thing ya really need the second body for is to hold the peddle down.
Re: Bleeding Brakes, without a helper [Re: ] #2778816
05/27/20 05:39 PM
05/27/20 05:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Here's what I use, just pump it up and go to each corner with my Gatorade bottle and a clear plastic tube up I make my living with it so the price tag was a little easier to swallow twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Bleeding Brakes, without a helper [Re: fourgearsavoy] #2778822
05/27/20 05:46 PM
05/27/20 05:46 PM
Gus beer
OMG Gus, are you selling bogus brake flushes? laugh2
Re: Bleeding Brakes, without a helper [Re: Guitar Jones] #2778833
05/27/20 06:13 PM
05/27/20 06:13 PM
Rittman Ohio
Rittman Ohio
Gus beer
HaHaHa we do have a couple writers that try to sell those scams but I mainly bought it because up here in the rust belt we get a fair amount of brake line work. When I do truck frame replacements Toyota gives us all new lines from the ABS actuator to all four corners. It's just much easier to pressurize the system and flush all the rust through the calipers. Time is money wrench
Gus beer
64 Plymouth Savoy
Dana 60
Re: Bleeding Brakes, without a helper [Re: fourgearsavoy] #2778837
05/27/20 06:29 PM
05/27/20 06:29 PM
5thAve Offline
5thAve  Offline
I usually do the gravity bleed method.
Someone also recently sent me a youtube video where someone used a spray top like from a windex bottle and a hose to hook it up to the bleeder and sprayed into an old container. Sort of like the method when you use a vacuum pump but cheaper.
Re: Bleeding Brakes, without a helper [Re: fourgearsavoy] #2778841
05/27/20 06:37 PM
05/27/20 06:37 PM
Mr T2U Offline
Mr T2U  Offline
Gus beer
when i do my 08 mustang i have a Motive pressure bleeder. takes about 10 min to flush the bake fluid after the wheels are off. i have 6 piston calipers in front 4 piston in rear.
ford motive brake bleeder.
for mopars maybe this would do the trick.
motive mopar brake bleeder
Re: Bleeding Brakes, without a helper [Re: mopar97] #2778845
05/27/20 06:48 PM
05/27/20 06:48 PM
5thAve Offline
5thAve  Offline
I bought this years ago, now I just stick the hose in the bottle.
https://www.oreillyauto.com/detail/...arracuda?q=brake+bleeder+tools&pos=3
I've got one of those too but never used it. Mine has a magnet on the side of the container so you can stick it somewhere where it won't get knocked around.
Re: Bleeding Brakes, without a helper [Re: Guitar Jones] #2778887
05/27/20 08:39 PM
05/27/20 08:39 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Gus beer
Never GUESS what Gus is gonna do !
Now jsta how does the BANJOnes do a TOTAL BRAKE FLUSH ??!
Re: Bleeding Brakes, without a helper [Re: dOoC] #2778910
05/27/20 09:37 PM
05/27/20 09:37 PM
I use a vacuum bleeder. But I rarely ever do one and I don't sell them. I spend my days doing major engine repair and replacement.
Re: Bleeding Brakes, without a helper [Re: BDW] #2778914
05/27/20 09:42 PM
05/27/20 09:42 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
da gravity bleed, then to finish place board on brake ped, lean wrapped cement block on board leveraging on pedal.
Open furthermost bleeder let fluid or air run, common sense and not being the first time tells you when to close bleeder, go lift block pump ped by hand, repeat.
I can final bleed a whole car alone in about 20 minutes.
Most of use figured this stuff out as a teen with there first mopar.
How do some people manage to breath on there own.
STOP POTATO HATE!
Re: Bleeding Brakes, without a helper [Re: Guitar Jones] #2778916
05/27/20 09:44 PM
05/27/20 09:44 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
But yet ya cant easily change a cam in a 40 year old rig, what the hell.
STOP POTATO HATE!
Re: Bleeding Brakes, without a helper [Re: Mr PotatoHead] #2778943
05/28/20 12:07 AM
05/28/20 12:07 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I've always gravity bled brakes on my cars, but that wouldn't work on my 2013 Acura SUV with ABS. So I used a hand operated vacuum bleeder to pull out all the old fluid. The result was all new fluid in the system and a pedal with erectile dysfunction, very soft.
Bought 20 ft of clear vinyl tube and ran the hose from each wheel cylinder one by one up to the master while gently pumping the pedal a few hundred times. From the driver seat I could see bubbles traveling up the tube. Problem solved. Took about an hour. This same procedure is said to bleed the master without needing to do bench bleeding.
Each wheel cylinder had one discreet batch of bubbles. Once they were gone, the system was good. The vacuum bleeder obviously had sucked air down the bleeder valve threads. Maybe I should have put grease on the threads? Next time I'll try that.
Re: Bleeding Brakes, without a helper [Re: 70sixpkrt] #2778946
05/28/20 12:23 AM
05/28/20 12:23 AM
Central Mississippi
mopar97 Offline
mopar97  Offline
Central Mississippi
Sure, I been doing it This way for 30 years with no
Problem. Its a sealed system so where does dirt come from? It is also a liquid, it doesn’t lose any Needed quality's as it ages.
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: Bleeding Brakes, without a helper [Re: AndyF] #2778954
05/28/20 01:05 AM
05/28/20 01:05 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted by AndyF
I always bleed brakes by myself. I prefer to work alone on some tasks so I can concentrate on what is going on rather than chatting. Here is the homemade setup that I use.
Well, don't concentrate too hard there andy: pity
lol, OMG typical Moparts Shade Tree Mechanics: Where on Earth is Richard Ehrenberg when you really need him? laugh2
I'm not a Mechanic by any stretch of the imagination, but, you Dummies do know that the reservoir that is capturing the brake fluid is supposed to be ABOVE the caliper? An air bubble always rises UP. It can't be forced DOWN if the reservoir is above the bleed screw. LOL. tonguue
No wonder you guys complain about the brakes on these cars, you don't know what you are doing! laugh2 My factory brakes will put people through the windshield! up
36 replies and 2 of you Clowns have posted incorrect photos of your one-man set-ups.
As usual, someone from another forum will find this thread on google and think Mopar People are clueless, thanks alot.
Mo' Farts
Moderated by "tbagger".
Re: Bleeding Brakes, without a helper [Re: Grizzly] #2778955
05/28/20 01:10 AM
05/28/20 01:10 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I use this: (and I wire it above the brakes)
Mo' Farts
Re: Bleeding Brakes, without a helper [Re: Grizzly] #2778963
05/28/20 02:14 AM
05/28/20 02:14 AM
Why do you wire it above the brakes, gravity doesn't flow well uphilll work grin
Page 2 of 3 1 2 3
