Un-bending Trans lines (from shipping) #2778670
05/27/20 11:24 AM
05/27/20 11:24 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I ordered some pre-bent trans lines. Of course to save $5 on shipping they bent on line in 2 spots. What is the best way to un-bend it w/o messing up the line.
Coming soon!!!!
Re: Un-bending Trans lines (from shipping) [Re: Mr.Yuck] #2778679
05/27/20 11:50 AM
05/27/20 11:50 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
If it was the company place or choice to bend it like that and not your doing, I'd contact the company and let them know about it and have them ship you one that isn't bent.
Re: Un-bending Trans lines (from shipping) [Re: DusterKid] #2778716
05/27/20 12:39 PM
05/27/20 12:39 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
They bend the line so the box doesn't have to so long/large. Pretty sure they all do it.
Re: Un-bending Trans lines (from shipping) [Re: Mr.Yuck] #2778750
05/27/20 02:29 PM
05/27/20 02:29 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I just had a fine line brake line for my crewcab, long bed 2003 Dodge and it was shipped in a small box it had three bends in it. I simply laid it out on the floor and worked out each way from the bend. They flattened out very good and look and fit exactly in the stock spot.
eBay-cdwmotorsports
Re: Un-bending Trans lines (from shipping) [Re: cdwmotorsports] #2778760
05/27/20 02:46 PM
05/27/20 02:46 PM
robertop Offline
robertop  Offline
Summit sells a tool to straighten small tubing, but it's expensive; maybe you can find a cheaper one on line. It has two rows of rolls and you adjust the space between the two rows and pass the tubing between the two rows. That what's the industry uses for industrial applications of any size and will certainly work for you.
Re: Un-bending Trans lines (from shipping) [Re: robertop] #2778765
05/27/20 03:06 PM
05/27/20 03:06 PM
md
mopars4ever Offline
mopars4ever  Offline
md
At one time they would includes instructions on how to flatten the lines back out. Maybe they no longer include it?
Re: Un-bending Trans lines (from shipping) [Re: mopars4ever] #2778798
05/27/20 04:42 PM
05/27/20 04:42 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
This...
The gentle bends straighten out very easily. Just set the bend on the ground and slowly unbend it. Using the ground is key. Don't just try to unbend it while holding it in the air.
Re: Un-bending Trans lines (from shipping) [Re: burdar] #2778810
05/27/20 05:27 PM
05/27/20 05:27 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I've straightened out lines with a couple 2x4's and a heavy dead blow mallet. I just drive to Finelines about 10 minutes from my home and pick them up unbent devil
Gus beer
64 Plymouth Savoy
Dana 60
Re: Un-bending Trans lines (from shipping) [Re: mopars4ever] #2778994
05/28/20 08:32 AM
05/28/20 08:32 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
they are in there, just wanted to see if anybody had a trick or better way.
