Moser Dana 60 Question #2778026
05/25/20 12:10 PM
05/25/20 12:10 PM
Phila Pa
scatpacktom Offline OP
Phila Pa
A friend of mine needs a hand setting up a Moser Dana 60.
My question is, does the Moser unit have spanners in them like the Strange Dana or do I need to take my spreader? I have orig Dana's and Strange Dana's but I have no experience with Moser
Re: Moser Dana 60 Question [Re: scatpacktom] #2778042
05/25/20 01:22 PM
05/25/20 01:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'd say take your spreader because I think the only threaded housings are made by Strange as the S60. They might hold the patent for the adjustable D60 because they are the only manufacturer that advertises that feature. I think they borrowed the ides from the 14 bolt GM type truck rear..
Gus beer
64 Plymouth Savoy
Dana 60
Re: Moser Dana 60 Question [Re: fourgearsavoy] #2778203
05/25/20 10:49 PM
05/25/20 10:49 PM
Phila Pa
Phila Pa
Thanks Gus
Re: Moser Dana 60 Question [Re: fourgearsavoy] #2778230
05/26/20 01:30 AM
05/26/20 01:30 AM
New York, USA
Chargerfan68 Offline
New York, USA
I have a Moser Dana from about 2008 and no spanners. Need a spreader to remove diff.
Re: Moser Dana 60 Question [Re: Chargerfan68] #2778236
05/26/20 02:24 AM
05/26/20 02:24 AM
I've never used a spreader to disassemble or reassemble a stock Dana 60, I use a good pry bar under one of the ring gear bolts to start prying the carrier up enough to expose the axle hole and then use the bar on the other side to pry the carrier bearing race up enugh to use the pry bar in either axle hole and remove it.
I use between .013 to .015 additional carrier bearing shims to preload the carrier bearings after removing them and using my honed out set of set up carrier bearings to measure the width needed to get zero preload and go from there wrench scope
A good soft blow hammer is your friend on installing the carrier after that hammer up
Re: Moser Dana 60 Question [Re: Cab_Burge] #2778455
05/26/20 06:31 PM
05/26/20 06:31 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I do what you do Cab and I use some light oil on when putting the carrier in like WD-40
