Re: Trick Flow heads and E-85
[Re: birdtracker]
#2778156
05/25/20 07:51 PM
05/25/20 07:51 PM
Posts: 43,202 Bend,OR USA
Cab_Burge
I haven't bought and used a set of those heads yet on my bracket E85 S/P car yet but if they take a 3/4 inch reach plugs like SB and 426 hemi use try a Autolite #3933 or the next hotter 3934. I have ran these plugs in both of my bracket motors with aluminum Eddy Victor M.W. on the old motor and with the Indy 440-1 at 15.0 to 1 compression on the new 400 block stroker motor IHTHs
[Re: birdtracker]
#2781238
06/03/20 10:12 PM
06/03/20 10:12 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
I use the NGK 7 non projected tip with the 240 heads on E85. 440 with 13.2 Ross dome pistons, stock stroke.
It's a Mark Sullens Dominator.
Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: jughed]
#2781281
06/04/20 01:55 AM
06/04/20 01:55 AM
Cab_Burge
My first E85 motor (14.5 to 1 comp) did NOT like cold plugs, I was running the retracted gap Autolite race plugs, 3932 slow the car down compared to the 3933 and 3934, 3932 being colder The new motor is close to 15.0 to 1 on all eight cylinders and I'm going to be doing more tuning and learning on it this year, if we ever get to race like normal
[Re: jughed]
#2781321
06/04/20 09:44 AM
06/04/20 09:44 AM
Posts: 16,928 NC
440Jim
NC
I'll be doing the E85 change soon. Running 440-1s on a 540 @ 13.5:1. I like NGKs, and it was suggested that I start with the -9 heat range plugs. The NGK -9 plugs are very cold for normally aspirated engines. I suggest starting with -8 for 13.5 CR. The -7 might even be fine for longer plug life.
[Re: 65Fury440]
#2835928
10/22/20 02:06 AM
10/22/20 02:06 AM
Cab_Burge
No I have ran my 800 HP bracket motor on E85 since 2013, it does not like cold plugs at all I would start with a retracted gap NGK-6 (sorry for not knowing that part # ) and then maybe try a -7 later to see what your motor likes. I use Autolite race plugs, part # 3934 3/4 inch reach, 5/8 plug size with a retracted gap
[Re: 65Fury440]
#2836520
10/23/20 02:37 PM
10/23/20 02:37 PM
Posts: 1,178 Indy
FlyFish
Indy
My 408 (Eddy heads),13:1 compression uses NGK R5671A-7 plugs. Works great.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
