Trick Flow heads and E-85 #2778139
05/25/20 06:54 PM
05/25/20 06:54 PM
birdtracker Offline OP
Anyone running Trick Flow 240 or 270's and using E-85 for fuel. Looking for a spark plug recommendation. Thanks Birdtracker
Re: Trick Flow heads and E-85 [Re: birdtracker] #2778156
05/25/20 07:51 PM
05/25/20 07:51 PM
I haven't bought and used a set of those heads yet on my bracket E85 S/P car yet but if they take a 3/4 inch reach plugs like SB and 426 hemi use try a Autolite #3933 or the next hotter 3934.
I have ran these plugs in both of my bracket motors with aluminum Eddy Victor M.W. on the old motor and with the Indy 440-1 at 15.0 to 1 compression on the new 400 block stroker motor shruggy
IHTHs scope
Re: Trick Flow heads and E-85 [Re: birdtracker] #2778341
05/26/20 01:16 PM
05/26/20 01:16 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I'll be doing the E85 change soon. Running 440-1s on a 540 @ 13.5:1. I like NGKs, and it was suggested that I start with the -9 heat range plugs.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Trick Flow heads and E-85 [Re: birdtracker] #2781238
06/03/20 10:12 PM
06/03/20 10:12 PM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
I use the NGK 7 non projected tip with the 240 heads on E85. 440 with 13.2 Ross dome pistons, stock stroke.
It's a Mark Sullens Dominator.
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: Trick Flow heads and E-85 [Re: jughed] #2781281
06/04/20 01:55 AM
06/04/20 01:55 AM
My first E85 motor (14.5 to 1 comp) did NOT like cold plugs, I was running the retracted gap Autolite race plugs, 3932 slow the car down compared to the 3933 and 3934, 3932 being colder
The new motor is close to 15.0 to 1 on all eight cylinders and I'm going to be doing more tuning and learning on it this year, if we ever get to race like normal luck
Re: Trick Flow heads and E-85 [Re: jughed] #2781321
06/04/20 09:44 AM
06/04/20 09:44 AM
NC
440Jim Offline
440Jim  Offline
NC
The NGK -9 plugs are very cold for normally aspirated engines. I suggest starting with -8 for 13.5 CR. twocents
The -7 might even be fine for longer plug life.
Re: Trick Flow heads and E-85 [Re: 440Jim] #2781593
06/05/20 07:28 AM
06/05/20 07:28 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We made the switch to E85 this season. I have 440-1 heads and run the -8 NGK. They seem to work good. I ran -9 plugs with Methanol and they worked ok. I read E85 likes a hotter plug.
Re: Trick Flow heads and E-85 [Re: cl440] #2835885
10/21/20 10:02 PM
10/21/20 10:02 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Old thread revival....
Would the NGK R5671A-8 plug be a reasonable place to start with a 12.5-1 E85 RB?
Re: Trick Flow heads and E-85 [Re: 65Fury440] #2835928
10/22/20 02:06 AM
10/22/20 02:06 AM
No tsk
I have ran my 800 HP bracket motor on E85 since 2013, it does not like cold plugs at all whiney I would start with a retracted gap NGK-6 (sorry for not knowing that part # blush) and then maybe try a -7 later to see what your motor likes.
I use Autolite race plugs, part # 3934 up 3/4 inch reach, 5/8 plug size with a retracted gap scope
Re: Trick Flow heads and E-85 [Re: Cab_Burge] #2836077
10/22/20 01:02 PM
10/22/20 01:02 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Thanks cab, I'll start there then.
Re: Trick Flow heads and E-85 [Re: 65Fury440] #2836102
10/22/20 01:56 PM
10/22/20 01:56 PM
Cab is correct, 6 or 7 on the heat range, and also non extended tip for E-85. Birdtracker
Re: Trick Flow heads and E-85 [Re: 65Fury440] #2836520
10/23/20 02:37 PM
10/23/20 02:37 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My 408 (Eddy heads),13:1 compression uses NGK R5671A-7 plugs. Works great.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Trick Flow heads and E-85 [Re: FlyFish] #2836760
10/23/20 10:21 PM
10/23/20 10:21 PM
Have you tested a hotter plug in your motor on a back to back test with no other changes?
If not me thinks you should scope wrench twocents I'm pretty sure you will be surprised up scope
Re: Trick Flow heads and E-85 [Re: Cab_Burge] #2837178
10/25/20 07:16 AM
10/25/20 07:16 AM
also E-85 likes the blue HVC coil. I changed from a Blaster 2 to the HVC and the difference was tremendous.
Birdtracker
https://www.jegs.com/i/MSD/121/8253...08M7P7AIVxwiICR0QxgwZEAQYAyABEgIl5PD_BwE
