Re: 70 Satellite lights flickering
[Re: Paul_B]
#2778058
05/25/20 01:59 PM
05/25/20 01:59 PM
Posts: 31,029 Oregon
AndyF
Could be most anything with that description. Wiring harness, grounds, charging system, etc. Spend a little time cleaning connections and then check things with a voltmeter and you'll find it.
I had a buddy who had a Mustang with flickering lights. He had his alternator tested and replaced. He replaced the voltage regulator, charged the battery, replaced battery cables, replaced the headlight switch, etc. Finally replaced the headlight wiring harness and that solved the problems. Evidently the factory wiring harness had broken just enough wire strands that the lights flickered when he drove. Just about drove him batty looking for that flicker.
[Re: 70runner]
#2778299
05/26/20 11:20 AM
05/26/20 11:20 AM
RapidRobert
regulator if it is an electromechanical reg & if not then the alt as mentioned
[Re: Paul_B]
#2778538
05/26/20 10:13 PM
05/26/20 10:13 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Or it just could be normal. The lights ....are fine when it’s not running. Lets begin here. When the engine is not running, power for the lights comes from the battery. The battery has a pretty big reserve of power. If the battery goes to 12.5 Volts when the lights are turned on, its going to stay around 12.5 volts for quite some time. So as long as all the connections from the battery to the lamps are good, everything is going to stay pretty steady. Of course eventually the battery will lose enough power that you will notice the lights dim. The lights flicker when the car is running... When running, the ammeter shows a normal charge, but will go to a quick slight discharge and back to a charge. The flickering seems to be periodic occurring every second or two. The voltage regulator will attempt to keep system voltage around 14 Volts. At 14 Volts, the lights will draw more current than at 12.5 Volts and they will burn brighter. Some headlights are more sensitive to this than others, but all lights do it. But at slow idle, the alternator can't produce a lot of power. It should be enough to run the ignition and a little more. Turning on the headlights and stepping on the brake pedal can sometimes max out an alternator's power at 650 or 700 rpm. If in addition to that, the battery is still recharging, and the alternator is already maxed out, system voltage will drop. Then the battery takes over for a little bit and you see it ammeter showing battery discharge, then charge, then discharge. So that's one common scenario and was pretty normal. Any suggestions on where to start? Same as the others. Make sure the battery is fully charged using a charger. Then after starting, let the battery recharge. When the ammeter indicates the battery is nearly recharged (or at least less than 5 amps charging), then try the headlights while holding the engine speed up around 1000 - 1200 rpm. If it still flickers and the ammeter still drops back to discharge, then the alternator is not producing nearly what it should. First check the belt tension. Then if that's not is, check for a bad diode or open winding in either the rotor or the stator.
