Power Steering Cooler I.D. Question
#2776900
05/22/20 01:45 AM
05/22/20 01:45 AM
Posts: 157 none
The Black Car
none
Hi gang! I need some help with the ID of P/S cooler. There is a date stamp of 3024 ; which I think is Nov. 7th 1969, and them the rest....I need help with!!!
Here are some photos to help you all help me! Should I sand blast it? Or leave it alone?
THANK YOU!!!!!!!!
Re: Power Steering Cooler I.D. Question
[Re: 6bblgt]
#2776907
05/22/20 02:29 AM
05/22/20 02:29 AM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
here's a proper musclecar Saginaw power steering cooler the one pictured above has the bracket bent - if fixed, it would mount correctly - but the lines are pointing in the wrong direction if that's off a MOPAR - - I'm thinking 1975 C-body "cop car"
[Re: 6bblgt]
#2777103
05/22/20 04:17 PM
05/22/20 04:17 PM
Posts: 157 none
The Black Car
none
[u][/u]
Thanks for the quick reply and info.
I put the bracket “back” where it belongs, now fits perfectly. Lines are not a problem, just need a little adjustment, its for a C-body so it’s perfect.
[Re: The Black Car]
#2779441
05/29/20 12:37 PM
05/29/20 12:37 PM
Posts: 3,490 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Interesting. Prob 40 years ago in HR / PHR/ CC mag there was an article on homemade "cool cans" for fuel lines. Insulated Ice bucket with two PS coolers like this, in sequence. Fill bucket with ice/ice water/dry ice, plumb fuel lines to it, and chill your gas at the track.
