M&H Door Jamb Connector #2776555
05/20/20 06:08 PM
05/20/20 06:08 PM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
I recently finished rewiring my 70 Charger, but one of the door jamb connectors (two on each switch) ripped off. It looks like a 56 series, but not the 1/4” size, its closer to the 3/16” size that other types come in. Does anyone know where to get these connectors or am I stuck getting a different kind? Also M&H was no help.
Re: M&H Door Jamb Connector [Re: 70charger512] #2776559
05/20/20 06:23 PM
05/20/20 06:23 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Heres the small 56 connector next to a 1/4” 58 series.
Re: M&H Door Jamb Connector [Re: 70charger512] #2776578
05/20/20 07:58 PM
05/20/20 07:58 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Try a local electronics shop. The kind that sells anything to do with radio, stereo, CB, etc. If you can not find a local one, pm me and I'll give you the name of a shop that I know will have them in stock.
Re: M&H Door Jamb Connector [Re: 70charger512] #2776988
05/22/20 11:33 AM
05/22/20 11:33 AM
None
71rm23 Offline
71rm23  Offline
None
Here is one of many to view.
https://www.repairconnector.com/
Re: M&H Door Jamb Connector [Re: 70charger512] #2778549
05/26/20 10:48 PM
05/26/20 10:48 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
When you can, post a photo of the connector too.
What you are showing with side rolled springs is a "Chrysler style" terminal. Terminal is the term you'll want to use when looking for these.
Packard 58 series and AMP Fast-on are two other groups of terminals using that form of retension.
Packard 58, like Packard 56 is strictly 1/4" wide.
Packard 59 is bigger, so that's one to look for.
Sometimes, but not always, a Packard terminal or AMP terminal will fit properly in a 'Chrysler' connector and visa versa.
Packard = Delphi = Aptiv (the most current name)
I had some luck with terminals made for Japanese motorcycles. So that's worth looking into.
http://www.easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/open_barrel.html
Some terminals
https://www.repairconnector.com/categories/ALL-TERMINALS-AND-KITS/WIRE-TERMINALS/
These folks have pretty much all that Auvco offers. Not perfectly organized, so you'll have to hunt to se if they have the wider terminals.
https://www.clipsandfasteners.com/O-E-M-Terminals-Shells-s/259.htm
Mouser has Packard 58 in stock (some).
https://www.mouser.com/Aptiv/Automotive-Connectors/Series-58/_/N-1z0zlezZ1ehb5Z1y9jlfy
https://www.mouser.com/Aptiv/Connectors/Automotive-Connectors/59-Series/_/N-1ehb5?P=1z0zlezZ1z0wv2h
The long version here
https://www.forabodiesonly.com/mopa...e-wire-terminals.418908/#post-1972965743
These are not exactly the same as the original Chrysler terminals, but probably close enough to get you a cigar.
Re: M&H Door Jamb Connector [Re: Mattax] #2826527
09/29/20 04:42 PM
09/29/20 04:42 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Thank you guys very much, I haven't been on here in awhile, but I did find what look to be the correct size terminals from McMaster-Carr. Were the terminals for the 2 prong door jambs not originally .187" like the M&H harness, or are they just harder to find for some reason?
Re: M&H Door Jamb Connector [Re: 70charger512] #2826767
09/30/20 08:38 AM
09/30/20 08:38 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
If you do find the correct terminal at McMaster, can you post their part number here? Would be handy to have.
Re: M&H Door Jamb Connector [Re: njmopar] #2826826
09/30/20 11:08 AM
09/30/20 11:08 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
The part number for the .187" size is 69525K19, which is for 22-18. I haven't been able to look at them yet, but can someone confirm if these are right?
Re: M&H Door Jamb Connector [Re: 70charger512] #2826982
09/30/20 03:36 PM
09/30/20 03:36 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
Quote
I probably have one on my original harness if you want me to clip it off.
Jeff
Re: M&H Door Jamb Connector [Re: njmopar] #2827247
10/01/20 09:44 AM
10/01/20 09:44 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Yes, I would like that too....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: M&H Door Jamb Connector [Re: Cuda340] #2827796
10/02/20 10:54 AM
10/02/20 10:54 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Jeff [/quote]
If you could measure it simply for research purposes that would be great. It just seems like it's too hard to find a connector in this size if it was OEM.
Re: M&H Door Jamb Connector [Re: 70charger512] #2881291
01/28/21 02:14 PM
01/28/21 02:14 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Just for future help I wanted to update this thread. I'm still not sure if these small terminals were or were not OEM, but they were fitting my original 2 prong door jamb switch. The McMaster-Carr 3/16" terminal that I referenced earlier fit well, just a simple crimp and it went on the door switch.
