361 5-Bolt Water Pump #2776558
05/20/20 06:12 PM
05/20/20 06:12 PM
McGregor,Iowa 52157
500ciDuster Offline OP
McGregor,Iowa 52157
I looking for a water pump for my 1975 D-700, are there any good sources? Maybe I could rebuild it myself if they don't exist
Re: 361 5-Bolt Water Pump [Re: 500ciDuster] #2776587
05/20/20 08:22 PM
05/20/20 08:22 PM
Guitar Jones Offline
I found the Gates number 43029 but every site that lists it shows a fuel filler neck, sooo, I don't know. Maybe call a truck parts place like Truck Pro. I'm sure Egg Machine could rebuild it for you.
Re: 361 5-Bolt Water Pump [Re: Guitar Jones] #2776629
05/20/20 11:02 PM
05/20/20 11:02 PM
Id
mopeman Offline
mopeman  Offline
Id
I just went through this last year with my '75 D600. After days of searching I found a GMB 120-1220 that worked, though it does look a little different from my stock pump.
https://www.amazon.com/GMB-120-1220-Replacement-Water-Gasket/dp/B000C6SL9E
https://autoplicity.com/3718209-gmb-north-america-120-1220
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: 361 5-Bolt Water Pump [Re: mopeman] #2776701
05/21/20 11:07 AM
05/21/20 11:07 AM
McGregor,Iowa 52157
McGregor,Iowa 52157
Great info and thank you, it almost looked like it should be on a tractor
Re: 361 5-Bolt Water Pump [Re: 500ciDuster] #2777138
05/22/20 06:25 PM
05/22/20 06:25 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Check your numbers as I think there are like 5 super-ceded numbers
pump
