Converting an A/C firewall to Non A/C ? #2776344
05/20/20 01:08 AM
05/20/20 01:08 AM
Phoenix, AZ
Jjs72D Offline OP
Deep in the closet
Jjs72D  Offline OP
Deep in the closet
Phoenix, AZ
My '72 Duster is an original A/C car but I may consider an aftermarket kit to replace the stock system. The Classic Auto Air setups use a compact unit with the fan motor fully inside the car under the dash. The kit comes with block off plates but to me, they look bad. I want a smooth firewall or at least, something that looks cleaner.
My welding skills are limited but getting better. I am faced with maybe just making a sheet metal cover for the firewall and welding around the perimeter.
Any tips on what I should do? I'll have the seats and carpet out to avoid fires.
Re: Converting an A/C firewall to Non A/C ? [Re: Jjs72D] #2776360
05/20/20 05:25 AM
05/20/20 05:25 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I converted a 67 Dart firewall from AC to non AC, got the non AC "plug" from the salvage yard and fitted it in as shown below...if I posted them correctly, first pic should be before, second pic during install and last pic when finished, hope this helps, up
1589966249046_20180928_202046-1.jpg1589966269208_20181226_144929-1.jpg20181227_132407-1.jpg
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Converting an A/C firewall to Non A/C ? [Re: Jjs72D] #2776375
05/20/20 08:15 AM
05/20/20 08:15 AM
Andrewh Online content
Andrewh  Online Content
The stock under dash part is much better than the general one they make.
They also make "rebuild" supplies for the original a/c under dash parts.
The blower motor is better and the surface area is better.
You can just do the compressor portion and maybe new condenser and keep your under dash part if you can.
Re: Converting an A/C firewall to Non A/C ? [Re: Andrewh] #2776433
05/20/20 12:13 PM
05/20/20 12:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What do you plan on doing for heat and defrost?
Re: Converting an A/C firewall to Non A/C ? [Re: stumpy] #2776571
05/20/20 07:23 PM
05/20/20 07:23 PM
Phoenix, AZ
Jjs72D Offline OP
Deep in the closet
Jjs72D  Offline OP
Deep in the closet
Phoenix, AZ
I plan to use an aftermarket kit from Classic Auto Air.
Re: Converting an A/C firewall to Non A/C ? [Re: Jjs72D] #2776576
05/20/20 07:43 PM
05/20/20 07:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if your going full aftermkt, I would just cut the old out and weld in a new flat plate to make a smooth firewall
Re: Converting an A/C firewall to Non A/C ? [Re: gtx6970] #2776621
05/20/20 10:21 PM
05/20/20 10:21 PM
Phoenix, AZ
Jjs72D Offline OP
Deep in the closet
Jjs72D  Offline OP
Deep in the closet
Phoenix, AZ
Thank you, that makes the most sense.
