Re: Won't start, I am throwing in the towel
[Re: buildanother]
#2775946
05/18/20 08:51 PM
05/18/20 08:51 PM
Posts: 11,596 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I can't imagine a stuck choke on an otherwise properly working carb causing THAT much fuel to get into the engine that it was squirting out the plug hole. It would be going out the exhaust as the engine turned over.
[Re: 57Fury440]
#2776066
05/19/20 08:53 AM
05/19/20 08:53 AM
Posts: 235 Central Mississippi
mopar97
Central Mississippi
You may want to clean the spark plugs too. I am sure they are fuel fouled. Burn the tips with a lighter and clean them with brake clean. That may get it to fire up....
Mopar born, Mopar breed, when I die, call me Mopar dead!
[Re: lockjaw-express]
#2776687
05/21/20 10:16 AM
05/21/20 10:16 AM
RapidRobert
Well, You got me hooked! Please let us know the outcome, as I am sure that others are waiting for the first fire-up! Mark X2!
[Re: NITROUSN]
#2776951
05/22/20 09:36 AM
05/22/20 09:36 AM
Posts: 250 Iceland
BadMoonRacer
Iceland
The poster needs to hire a good mechanic for one hour and the car would be running. I disagree. This guy is in a steep learning curve and honest in his descriptions. When he has fixed the issue, he will be wiser and more talented, than if a mechanic fixes it and takes his money. Cudos to everybody who steps in to help him. Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
[Re: moparx]
#2777876
05/24/20 11:23 PM
05/24/20 11:23 PM
Posts: 2,941 GA
roadrunninMark
GA
[Re: moparx]
#2778190
05/25/20 09:44 PM
05/25/20 09:44 PM
Posts: 357 The Garden State
LimelightCuda
The Garden State
make that x3 ! Make that x4! I am looking forward to hearing you got it running! Keep us posted.
Phil
1970 Barracuda Gran Coupe 1970 A66 Challenger Convertible
[Re: mopar97]
#2785510
06/14/20 08:38 PM
06/14/20 08:38 PM
Posts: 16 irvine, california
stephen
irvine, california
hi guys,
finally got some time this weekend, worked on the car a little bit.
was able to pry open the plate, it works fine now.
interesting new discovery: when throttling, the gas is not spraying from the jet, instead it is flowing like a facet. way too much gas. it wanted to start, but then always have big loud backfire.
it is a eldelbrok 4 barrel, there are two screws in the front to adjust air mixer, no matter what I do with them, still too much gas.
please help.
[Re: stephen]
#2785514
06/14/20 08:47 PM
06/14/20 08:47 PM
RapidRobert
interesting new discovery: when throttling, the gas is not spraying from the jet, instead it is flowing like a facet. bad needle/seat or float or float linkage & eddys dont like more than 5&1/2 lbs fuel psi & alot of OE pumps put out way more than that.
