Re: Help me identify this crankshaft
[Re: fastmark]
#2775414
05/17/20 01:25 PM
05/17/20 01:25 PM
Posts: 10,759 North Dakota
6PakBee
North Dakota
Before we get too far down the road, if your engine has a harmonic balancer like this, and a flexplate like this, it could be a heavy rod forged steel crank engine. This era was a real mish-mash with Mopar.
[Re: slantzilla]
#2775496
05/17/20 05:13 PM
05/17/20 05:13 PM
Posts: 236 Richmond , Virginia
chagjr
Richmond , Virginia
Did it shake in neutral just revving the engine up? No.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
[Re: 6PakBee]
#2775498
05/17/20 05:18 PM
05/17/20 05:18 PM
chagjr
Richmond , Virginia
It definitely has the 73 forged crank balancer.
Here is the converter and flex plate I removed.
Harry
[Re: chagjr]
#2775499
05/17/20 05:20 PM
05/17/20 05:20 PM
chagjr
Richmond , Virginia
Here is a photo of the balancer again-
Harry
[Re: chagjr]
#2775506
05/17/20 05:27 PM
05/17/20 05:27 PM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
We need to see pics of the front of the convertor. The weights you pictured are to balance a neutral balance convertor, show the front, that's where an external balanced convertor will be balanced at.
[Re: chagjr]
#2775507
05/17/20 05:27 PM
05/17/20 05:27 PM
chagjr
Richmond , Virginia
Like I mentioned before, I am pretty sure this is forged crank motor that had a miss match transmission set up. I am an enthusiast not a guru. I am making an educated guess hoping Moparts can massage out my uncertainty. The vibration only occurred at around 60 mph. 391 rear.
Here are the new flex plate and converter.
Harry
[Re: GODSCOUNTRY340]
#2775512
05/17/20 05:34 PM
05/17/20 05:34 PM
chagjr
Richmond , Virginia
We need to see pics of the front of the convertor. The weights you pictured are to balance a neutral balance convertor, show the front, that's where an external balanced convertor will be balanced at. Here is the front, no weights. So it could have been just the flex plate causing the vibration?
Harry
[Re: chagjr]
#2775514
05/17/20 05:38 PM
05/17/20 05:38 PM
GODSCOUNTRY340
Okay, that's a neutral balance convertor, no weights on front but the bite flex plate is for using that convertor on a cast crank engine. If your engine is a forged crank engine that is the wrong flex plate for it. Use your new flex plate.
[Re: fastmark]
#2775518
05/17/20 05:45 PM
05/17/20 05:45 PM
Posts: 25,995 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I’ve bought lots of motors over the years and I’m not sure I have ever seen a steel crank with no hole at all. The steel shafts I have in my possession all have some kind of a hole, even if it is too small. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) First pic with the shallow drill point cut looks like a cast crank.
#2775520
05/17/20 05:54 PM
05/17/20 05:54 PM
chagjr
Richmond , Virginia
Okay, that's a neutral balance convertor, no weights on front but the bite flex plate is for using that convertor on a cast crank engine. If your engine is a forged crank engine that is the wrong flex plate for it. Use your new flex plate. . Thanks for all of the help. I have another question regarding the transmission I removed. What did this come out of? This section was hitting the frame in the tunnel that the tranny cross member attaches to. It kept the transmission down a little causing the steering linkage to hit the oil pan when making a right turn. The new transmission tail shaft housing is what I am used to seeing. It does not have that.
Harry
[Re: chagjr]
#2775523
05/17/20 06:00 PM
05/17/20 06:00 PM
GODSCOUNTRY340
If you discover it IS a cast crank engine that convertor and bite flex plate is correct for it and someone has the wrong harmonic balancer on the engine.
#2775525
05/17/20 06:07 PM
05/17/20 06:07 PM
GODSCOUNTRY340
That's the snap ring access plate, you need a trans with that plate on the bottom by the trans mount or you could hammer the crossmember for fitment.
#2775526
05/17/20 06:09 PM
05/17/20 06:09 PM
chagjr
Richmond , Virginia
If you discover it IS a cast crank engine that convertor and bite flex plate is correct for it and someone has the wrong harmonic balancer on the engine. :(, ![cry cry](/ubbthreads/images/graemlins/custom/cry.gif) , ![sawzall sawzall](/ubbthreads/images/graemlins/custom/sawzall.gif)
Harry
#2775528
05/17/20 06:14 PM
05/17/20 06:14 PM
chagjr
Richmond , Virginia
That's the snap ring access plate, you need a trans with that plate on the bottom by the trans mount or you could hammer the crossmember for fitment. I am ready to go.... new transmission in the box,
Harry
[Re: chagjr]
#2775531
05/17/20 06:18 PM
05/17/20 06:18 PM
GODSCOUNTRY340
GOOD, now you just need to find out if the crank's cast or forged before you put that trans in place.
#2775534
05/17/20 06:25 PM
05/17/20 06:25 PM
chagjr
Richmond , Virginia
Gods country 340, you have filled in the blanks for me. Thanks so much for your help!
I should be ready to go when the current event of present time has passed.
Harry
[Re: chagjr]
#2775538
05/17/20 06:36 PM
05/17/20 06:36 PM
Posts: 10,168 A Red State
SNK-EYZ
A Red State
Okay, that's a neutral balance convertor, no weights on front but the bite flex plate is for using that convertor on a cast crank engine. If your engine is a forged crank engine that is the wrong flex plate for it. Use your new flex plate. . Thanks for all of the help. I have another question regarding the transmission I removed. What did this come out of? This section was hitting the frame in the tunnel that the tranny cross member attaches to. It kept the transmission down a little causing the steering linkage to hit the oil pan when making a right turn. The new transmission tail shaft housing is what I am used to seeing. It does not have that. You said this is in a Dart (A-Body), what oil pan are you using? A standard big block oil pan doesn't clear the center link/idler arm on a Dart, it has to have a recess in it or be reworked for clearance.
[Re: SNK-EYZ]
#2775556
05/17/20 07:35 PM
05/17/20 07:35 PM
chagjr
Richmond , Virginia
Okay, that's a neutral balance convertor, no weights on front but the bite flex plate is for using that convertor on a cast crank engine. If your engine is a forged crank engine that is the wrong flex plate for it. Use your new flex plate. . Thanks for all of the help. I have another question regarding the transmission I removed. What did this come out of? This section was hitting the frame in the tunnel that the tranny cross member attaches to. It kept the transmission down a little causing the steering linkage to hit the oil pan when making a right turn. The new transmission tail shaft housing is what I am used to seeing. It does not have that. You said this is in a Dart (A-Body), what oil pan are you using? A standard big block oil pan doesn't clear the center link/idler arm on a Dart, it has to have a recess in it or be reworked for clearance. I am pretty sure this is the correct pan. The second photo shows where it was hitting. I have been sorting this car out for a year and a half. I hop to have all of the gremlins out soon.
![Name: E31B7F13-FA80-42C0-8F26-0F371B101261.jpeg
ID: 394505 E31B7F13-FA80-42C0-8F26-0F371B101261.jpeg](/ubbthreads/ubbthreads.php/ubb/download/Number/394505/filename/E31B7F13-FA80-42C0-8F26-0F371B101261.jpeg) ![Name: D80531EA-4A00-4FF8-980C-51E87C3D2F93.jpeg
ID: 394506 D80531EA-4A00-4FF8-980C-51E87C3D2F93.jpeg](/ubbthreads/ubbthreads.php/ubb/download/Number/394506/filename/D80531EA-4A00-4FF8-980C-51E87C3D2F93.jpeg)
Harry
[Re: chagjr]
#2775613
05/18/20 12:05 AM
05/18/20 12:05 AM
SNK-EYZ
A Red State
While some people say that oil pan is what to use on an A-Body because it has the indentation, it doesn't really work (as you have found out). Both the 187 and the 699 oil pan have the indentation too far forward (close to the sump area). They simply don't clear, I've got a factory 69 383 GTS and tried both the 187 and 699 oil pans when I was mocking up everything in the engine compartment for clearance and neither one cleared the center link at the idler arm. The recess is in the wrong spot to clear. I ended up using a 7 quart Hemi pan that I recessed my self with a hammer and a larger socket to make clearance. I looked to see if I had a pic of the recess that I added, but none of the engine pics show that part of the oil pan. Both the 187 and 699 oil pans are actually listed as C-Body oil pans. http://www.440source.com/oilpans.htm
