Page 2 of 3 1 2 3
Re: Help me identify this crankshaft [Re: chagjr] #2775409
05/17/20 01:09 PM
05/17/20 01:09 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Originally Posted by chagjr
Originally Posted by Cab_Burge
Remove that after market flex plate and use a stock Mopar flexplate with a standard converter with no weights welded onto it twocents
That’s the plan up
Let’s us know the results.👍
Re: Help me identify this crankshaft [Re: fastmark] #2775414
05/17/20 01:25 PM
05/17/20 01:25 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Before we get too far down the road, if your engine has a harmonic balancer like this, and a flexplate like this, it could be a heavy rod forged steel crank engine. This era was a real mish-mash with Mopar.
Re: Help me identify this crankshaft [Re: slantzilla] #2775496
05/17/20 05:13 PM
05/17/20 05:13 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Originally Posted by slantzilla
Did it shake in neutral just revving the engine up?
No.
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: Help me identify this crankshaft [Re: 6PakBee] #2775498
05/17/20 05:18 PM
05/17/20 05:18 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
It definitely has the 73 forged crank balancer.
Here is the converter and flex plate I removed.
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775499
05/17/20 05:20 PM
05/17/20 05:20 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Here is a photo of the balancer again-
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775506
05/17/20 05:27 PM
05/17/20 05:27 PM
God's Country Maryland
GODSCOUNTRY340 Offline
We need to see pics of the front of the convertor. The weights you pictured are to balance a neutral balance convertor, show the front, that's where an external balanced convertor will be balanced at.
Re: Help me identify this crankshaft [Re: chagjr] #2775507
05/17/20 05:27 PM
05/17/20 05:27 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Like I mentioned before, I am pretty sure this is forged crank motor that had a miss match transmission set up.
I am an enthusiast not a guru. I am making an educated guess hoping Moparts can massage out my uncertainty.
The vibration only occurred at around 60 mph. 391 rear.
Here are the new flex plate and converter.
Harry
Re: Help me identify this crankshaft [Re: GODSCOUNTRY340] #2775512
05/17/20 05:34 PM
05/17/20 05:34 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Here is the front, no weights. So it could have been just the flex plate causing the vibration?
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775514
05/17/20 05:38 PM
05/17/20 05:38 PM
Okay, that's a neutral balance convertor, no weights on front but the bite flex plate is for using that convertor on a cast crank engine. If your engine is a forged crank engine that is the wrong flex plate for it. Use your new flex plate.
Re: Help me identify this crankshaft [Re: fastmark] #2775518
05/17/20 05:45 PM
05/17/20 05:45 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Originally Posted by fastmark
I’ve bought lots of motors over the years and I’m not sure I have ever seen a steel crank with no hole at all. The steel shafts I have in my possession all have some kind of a hole, even if it is too small.
iagree First pic with the shallow drill point cut looks like a cast crank.
Re: Help me identify this crankshaft [Re: GODSCOUNTRY340] #2775520
05/17/20 05:54 PM
05/17/20 05:54 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Thanks for all of the help. I have another question regarding the transmission I removed.
What did this come out of? This section was hitting the frame in the tunnel that the tranny cross member attaches to.
It kept the transmission down a little causing the steering linkage to hit the oil pan when making a right turn. The new transmission tail shaft housing is what I am used to seeing. It does not have that.
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775523
05/17/20 06:00 PM
05/17/20 06:00 PM
If you discover it IS a cast crank engine that convertor and bite flex plate is correct for it and someone has the wrong harmonic balancer on the engine.
Re: Help me identify this crankshaft [Re: GODSCOUNTRY340] #2775525
05/17/20 06:07 PM
05/17/20 06:07 PM
That's the snap ring access plate, you need a trans with that plate on the bottom by the trans mount or you could hammer the crossmember for fitment.
Re: Help me identify this crankshaft [Re: GODSCOUNTRY340] #2775526
05/17/20 06:09 PM
05/17/20 06:09 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
:(, cry, sawzall
Harry
Re: Help me identify this crankshaft [Re: GODSCOUNTRY340] #2775528
05/17/20 06:14 PM
05/17/20 06:14 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
I am ready to go.... new transmission in the box,
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775531
05/17/20 06:18 PM
05/17/20 06:18 PM
GOOD, now you just need to find out if the crank's cast or forged before you put that trans in place.
Re: Help me identify this crankshaft [Re: GODSCOUNTRY340] #2775534
05/17/20 06:25 PM
05/17/20 06:25 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Gods country 340, you have filled in the blanks for me.
Thanks so much for your help!
I should be ready to go when the current event of present time has passed.
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775538
05/17/20 06:36 PM
05/17/20 06:36 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
You said this is in a Dart (A-Body), what oil pan are you using?
A standard big block oil pan doesn't clear the center link/idler arm on a Dart, it has to have a recess in it or be reworked for clearance.
Re: Help me identify this crankshaft [Re: SNK-EYZ] #2775556
05/17/20 07:35 PM
05/17/20 07:35 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
I am pretty sure this is the correct pan.
The second photo shows where it was hitting. I have been sorting this car out for a year and a half. I hop to have all of the gremlins out soon.
Harry
Re: Help me identify this crankshaft [Re: chagjr] #2775613
05/18/20 12:05 AM
05/18/20 12:05 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
While some people say that oil pan is what to use on an A-Body because it has the indentation, it doesn't really work (as you have found out).
Both the 187 and the 699 oil pan have the indentation too far forward (close to the sump area).
They simply don't clear, I've got a factory 69 383 GTS and tried both the 187 and 699 oil pans when I was mocking up everything in the engine compartment for clearance and neither one cleared the center link at the idler arm.
The recess is in the wrong spot to clear.
I ended up using a 7 quart Hemi pan that I recessed my self with a hammer and a larger socket to make clearance.
I looked to see if I had a pic of the recess that I added, but none of the engine pics show that part of the oil pan.
Both the 187 and 699 oil pans are actually listed as C-Body oil pans.
http://www.440source.com/oilpans.htm
Page 2 of 3 1 2 3
