FIRE! Update vid and article - pg 2 #2774988
05/15/20 10:23 PM
05/15/20 10:23 PM
Fulton County, PA
CMcAllister Offline OP
Mr. Helpful
Mr. Helpful
Fulton County, PA
So I'm watching Wooostock at Darlington. No spectators but a pile of cars. People are ready to get out.
Anyway, maybe someone else saw it. Guys car erupts in flames at the finish line. Obvious fuel fire, totally involved. Gets it stopped and it's taking the track crew a little time to get on it. And it takes a long time - I mean a looong time - for him to get out. Long enough that I thought "he's in big trouble". Finally rolled out of the thing, just as the fire crew got on it with spray. Tears his jacket and stuff off because it was so hot.
Interviewed him later. Said he saw someone have a bad fire last year, so he had all his stuff updated. But. His HANS got caught in the cage and he couldn't get out. Had to stop and think and ended up having to take his damned helmet off to get out of the car. Had a head sock on that saved him from being burned. Luckily, he wasn't hurt at all.
Moral of the story? They used to make you do a blindfold test when you got your license. Don't recall seeing that done in a long time. But how many people have ever practiced or tried to see how long it took to get out of the car in an emergency.
Might be a good idea. Put your stuff on, strap in and close your eyes. Then try to do an emergency exit drill. See how long it takes, if you get tangled up in anything or if something needs to moved or adjusted. Consider putting a ON-OFF lever in reach for the master switch to get the pumps shut off fast. Seeing it happen to someone really makes you think.
Re: FIRE! [Re: CMcAllister] #2774994
05/15/20 10:43 PM
05/15/20 10:43 PM
New York, USA
Chargerfan68 Offline
New York, USA
That is a GREAT idea and reminder. I, for one, am def going to do that. Thanks for the reminder!! It could really, litrrally save lives doing that. Thx.
Re: FIRE! [Re: Chargerfan68] #2775031
05/16/20 08:14 AM
05/16/20 08:14 AM
birdtracker Offline
birdtracker  Offline
I also updated all my safety stuff this season. Shoes, socks , gloves and new head sock. The practice of getting out in an emergency has to be one of the best ideas. Hopefully you never have to do it in a real situation. Birdtracker
Re: FIRE! [Re: CMcAllister] #2775056
05/16/20 09:41 AM
05/16/20 09:41 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am amazed on how long it takes and a window net will really slow you down.I think I took 8sec.
Re: FIRE! [Re: CMcAllister] #2775060
05/16/20 10:00 AM
05/16/20 10:00 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I have a master cut off in car next to shifter, not only for safety, mostly the number of times I’ve gotten all strapped in and then realized I forgot to turn power on outside. The inside switch gets used the most now. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: FIRE! [Re: BANDIT] #2775146
05/16/20 02:27 PM
05/16/20 02:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Getting in and out of a car wearing a HANS can be an issue for sure. They stick up a good bit and can get hung up especially in a tight car. The lay back angle and height of the back of them is pretty significant. I went with a Neksgen for those reasons having caught a car on fire before. The little straps to release them from your helmet are not super easy to find when you are not in a hurry.
Re: FIRE! [Re: Al_Alguire] #2775170
05/16/20 04:01 PM
05/16/20 04:01 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Now after practicing.... do 5-6 shots of your Fave cocktail and try it again.
In a crash you may get your bell rung. You will act like you're drunk and may not do everything right.
In my 2015 Motorcycle crash after slamming the concrete bairrer at 75 MPH and sliding down the freeway 450+ feet I could not get my helmet off. I tried and tried. I thought I had undone the 'D' binder but had not. The State Patrol Trooper also had to sit me down as I was walking around.... with a broken leg. I rang my bell big time.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: FIRE! [Re: Al_Alguire] #2775250
05/16/20 09:36 PM
05/16/20 09:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Al..... having aided you in getting in your car, I can’t imagine getting out fairly quick.
Re: FIRE! [Re: Clanton] #2775254
05/16/20 09:49 PM
05/16/20 09:49 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Enders was stuck in a burning ProMod car for a long time last year because of that I believe. New parts were designed over the winter and are required this year in Pro Mod and Pro Stock. Definitely should be looked at for a new build or upgrade.
Re: FIRE! [Re: J_BODY] #2775255
05/16/20 09:49 PM
05/16/20 09:49 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Jay some of those old timers move pretty slow. Till the dinner bell sounds.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: FIRE! [Re: pittsburghracer] #2775272
05/16/20 11:11 PM
05/16/20 11:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
In my case more of a 10lbs of stuff in a 2lb bag. These modern pro stock style cars can be very tight. Especially when you have a -15 suit o. I keep my belts VERY tight and try t leave the lap belt at that tension all the time. Just not a lot room to adjust them once in. Jay has seen the circus of ingress and egress
Re: FIRE! [Re: Al_Alguire] #2775315
05/17/20 07:26 AM
05/17/20 07:26 AM
gregsdart Offline
gregsdart  Offline
And here I thought I was the only one that struggled. Being 6 ft and 270 pds plus 70 years old, it takes me a bit. Thanks for the post CMc, will practice and see if I can get out with helmet on!
Re: FIRE! [Re: gregsdart] #2775419
05/17/20 01:38 PM
05/17/20 01:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
This is a great thread! I am definitely going to practice getting out in a hurry. Maybe my window net and steering wheel tilt will need revisions for quick easy operation. I don't know till I practice. And a guy needs to consider, the car could be on the side or on the roof.
Look how quick Nick plewniak got out:
https://youtu.be/lJ8J-iowHN0
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: FIRE! [Re: gregsdart] #2775443
05/17/20 02:32 PM
05/17/20 02:32 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Honestly, I had never thought much about it, but this Mustang lit up like a bad funny car fire. And the guy wasn't coming out of it and the track crew had to come to him, took a few moments. Then the interview later on. Had to take his helmet off to get untangled. I just thought that would have been an awful stupid way to get burned or die.
Re: FIRE! [Re: CMcAllister] #2775448
05/17/20 02:40 PM
05/17/20 02:40 PM
PA.
"Little"John
"Little"John
PA.
After you guys get this down pat try it with the car on its roof in a 7.50 cert funny car caged dodge Daytona. I needed help.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: FIRE! [Re: CMcAllister] #2775476
05/17/20 04:29 PM
05/17/20 04:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Would have been interesting to know fuel line routing on that car....
Re: FIRE! [Re: pittsburghracer] #2775587
05/17/20 09:39 PM
05/17/20 09:39 PM
gregsdart Offline
gregsdart  Offline
No thanks! My first decent car was a 55chevy,,,,,,, hmmmm
Re: FIRE! [Re: gregsdart] #2775636
05/18/20 07:15 AM
05/18/20 07:15 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I saw a post From Jason Digby who had a conversation with him. I guess an EGT fitting had a crack around and it shot flame out of the pipe and cut a fuel line.
68 Barracuda Formula S 340
Re: FIRE! [Re: Bad340fish] #2776720
05/21/20 12:20 PM
05/21/20 12:20 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
