Calling brake experts #2775090
05/16/20 11:13 AM
05/16/20 11:13 AM
A727Tflite Offline OP
Finally found a Reman booster for my 93 D250 diesel. Have a fresh master cylinder now too. Comparing how much booster pushrod protrudes from the back of the booster versus the depth of the pushrod bore in the master using that same flange - No mention of any procedure in the service manual as to preferred clearance between the rod and piston.
Any experts out there on this and can you advice what clearance is called for?
Re: Calling brake experts [Re: A727Tflite] #2775123
05/16/20 12:55 PM
05/16/20 12:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
.020" seems to be the accepted standard.
Re: Calling brake experts [Re: John_Kunkel] #2775130
05/16/20 01:15 PM
05/16/20 01:15 PM
Thanks.
Surprised the service manual didn’t call this out.
Re: Calling brake experts [Re: A727Tflite] #2775873
05/18/20 05:47 PM
05/18/20 05:47 PM
hooziewhatsit Offline
Sounds about right. Too close, and there's a chance the brakes won't release when you let off the pedal, especially after they warm up.
Too far, and the pedal will be low due to the increased travel.
I made my own tool with three bolts and a threaded piece of 1/4" thick wood laugh2
