ZF 8 Speed #2693744
09/02/19 07:59 PM
09/02/19 07:59 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Re: ZF 8 Speed [Re: MattW] #2693785
09/02/19 09:51 PM
09/02/19 09:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sound German Automotive has a controller for the ZF8
Re: ZF 8 Speed [Re: MattW] #2698448
09/17/19 01:25 PM
09/17/19 01:25 PM
IL
W
wish4hemi Offline
wish4hemi  Offline
W
IL
Re: ZF 8 Speed [Re: MattW] #2701244
09/26/19 09:24 PM
09/26/19 09:24 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
That video show him running the trans with a cheap controller he made. Have no idea if it is true or not but seems real.
Fiat need to jump on this or even ZF out of Germany. They used this same trans ( Basic setup) with upgrades in the GT4 class at Neuenburg.
I believe they dropped the converter for a clutch. This trans is less than 200 lbs and can handle up to 750 ft lbs I think in the hp90 trim.
Googled 8 speed and got GM stuff engine and transmission controllers for swaps.
JESUS they R quick!!!!!
Re: ZF 8 Speed [Re: MattW] #2701624
09/28/19 04:21 AM
09/28/19 04:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Less than 200 lbs? The A-8 ? Have you actually seen one of these? They are huge. Is that with the converter and fluid?
How could they be around the same weight as a 727 ??
Re: ZF 8 Speed [Re: Kern Dog] #2701700
09/28/19 11:55 AM
09/28/19 11:55 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Re: ZF 8 Speed [Re: Kern Dog] #2701769
09/28/19 03:47 PM
09/28/19 03:47 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Less converter. Nor sure about fluids. Better design I guess.
If you can control it with an aftermarket controller or manually like the guy did in the video, then you have one heck of a trans for a swap.
Matt
Re: ZF 8 Speed [Re: MattW] #2701855
09/28/19 10:11 PM
09/28/19 10:11 PM
IL
furious70 Offline
furious70  Offline
IL
I keep posting in these TF-8 posts - the trans is 9" tall at the rear mount. It's a very different size and shape from a 727. FYI for all who've never seen one, it will take a lot of tunnel surgery. Not that it isn't a great trans, but it's going to be a lot more work than making a 518 fit.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: ZF 8 Speed [Re: furious70] #2774925
05/15/20 05:35 PM
05/15/20 05:35 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Has anyone heard about this company?
HTG Tuning?
Apparently they have a ZF standalone controller.
Re: ZF 8 Speed [Re: MattW] #2774931
05/15/20 06:05 PM
05/15/20 06:05 PM
GA
roadrunninMark Offline
GA
Here are some size pics I have collected. The first is comparing the Nag1 (center) to a 727 and 545. The second and third are the Nag1 vs. the 8 speed. I've heard of the Nag1 fitting in an ebody with just a little "persuasion" to the tunnel with a hammer. I don't know if the 8 speed will fit with that same "persuasion".
Re: ZF 8 Speed [Re: roadrunninMark] #2775024
05/16/20 07:25 AM
05/16/20 07:25 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
These transmissions work so well in the modern cars because of how integrated the controls are into the whole car. We have an 18 Durango R/T and I really like the how the 8 speed works but I think it would be really hard to do from the aftermarket.
68 Barracuda Formula S 340
Re: ZF 8 Speed [Re: Bad340fish] #2778774
05/27/20 03:45 PM
05/27/20 03:45 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
Its just a tune you put into them. Not sure if the 8-speeds are ZF tuned or FCA tuned, I know FCA has had troubles with their own tune in the ZF9 (FWD) used in the jeep cherokee with harsh shifts etc. Word is they called up ZF to help and now its fixed. Either or, it may work with a base tune from 6.4 car or the aftermarket can tweak it from there. I don't think it'll be too difficult.
Re: ZF 8 Speed [Re: SRT6776] #2931328
06/08/21 03:36 PM
06/08/21 03:36 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
bump
Re: ZF 8 Speed [Re: MattW] #2938562
06/30/21 11:04 PM
06/30/21 11:04 PM
GA
GA
I just got one of these transmissions. My friend and I are both going to put in an ebody. I won't be ready for body mods until probably next year but we are working on getting it all hooked up properly behind our small blocks.
Re: ZF 8 Speed [Re: MattW] #2939626
07/03/21 09:51 PM
07/03/21 09:51 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
HTG Tuning?
Yeap used HTG to swap a 8sp out of a 2015 Ram 4x4 in to a 77 Ramcharger, took awhile to get it from over the pond to here in Eastern PA.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: ZF 8 Speed [Re: MattW] #2939627
07/03/21 09:55 PM
07/03/21 09:55 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Irony when you think about it, for a while there swapping the 4l80e was the hot ticket for Mopar guys now swapping the ZF trans is the hot ticket for GM guys....Ohhhh the Horror or it all
Re: ZF 8 Speed [Re: ric3xrt] #2939728
07/04/21 10:04 AM
07/04/21 10:04 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
They are are just a dealer for PCS, If you visit the PCS website you will get a list of dealers. Who sells what you will have to do the leg work.
https://www.soundgermanautomotive.com/pcs/
https://www.powertraincontrolsolutions.com/Performance_Aftermarket/Dealers/
Re: ZF 8 Speed [Re: ric3xrt] #2942576
07/13/21 10:36 AM
07/13/21 10:36 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
HTG Tuning?
Stop teasing us!!!
How does it work??
Would love to see a detailed report on this.
