Page 2 of 10 1 2 3 4 9 10
Re: TH400 to RB in 69 b body info [Re: TRENDZ] #2762019
04/09/20 07:14 PM
04/09/20 07:14 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I took the last 2yrs off running it n/a to think about it so ya I gave it time.
Originally Posted by TRENDZ
Turbo400 is a good trans. Can be built to hold a lot of power pretty inexpensively. The same could be said for a properly built torqflite. The benefits of installing a 400 into a B body, are not... for most, worth the effort. I understand being soured on parts. But It seems that maybe you would be best off to step back, take a breath, and re-evaluate your choice of trans builder. I assure you you are not making enough power to need to walk away from a TF.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762185
04/10/20 09:16 AM
04/10/20 09:16 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I ordered a Rossler stage 4 Rossler trans
Re: TH400 to RB in 69 b body info [Re: 6bblFLASH] #2762192
04/10/20 09:26 AM
04/10/20 09:26 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by 6bblFLASH
IMO with the blower forget horsepower, worry about the torque.
....which makes me think of the 47/48 RE torqueflight based trans behind the hopped up Cummins ISB smile
Just curious Clanton, was it repeated failure of one component? ...or a few instances of breakage. Iโ€™d still say at the level your at our favorite dump truck trans should be able to handle the task at hand.
Sounds like your next step is getting a JY core and start mocking things up.
Are there adapter kits available? I know pretty much zero about this. I do find it interesting how long people have been putting glides behind Mopars and still read about parts fitment issues here and there.
Hopefully youโ€™ll start a post on this endeavor, or keep adding to this one. Lord knows we need reading material these days.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762200
04/10/20 09:52 AM
04/10/20 09:52 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
So now you are broke LOL.๐Ÿ™Š
ROSSLER builds good stuff.
Keep us posted on progress and results.๐Ÿ‘๐Ÿ‘‹
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: TH400 to RB in 69 b body info [Re: 6bblFLASH] #2762211
04/10/20 10:09 AM
04/10/20 10:09 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am not broke but 4,700$ is a lot just for the trans.I had a goal in mind when I started this and I will keep at it as long as I can.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762216
04/10/20 10:19 AM
04/10/20 10:19 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
up beer
Re: TH400 to RB in 69 b body info [Re: 6bblFLASH] #2762228
04/10/20 10:36 AM
04/10/20 10:36 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
This is where MOPARTS gets tunnel vision...and why most MOPAR guys are slower than the Brand X guys....
Someone asked about fitting a T400 to a B body, hes looking for info, what needs to be done.
Instead of helping him, you guys are chastising him, telling him a 727 will work, and he don't need a 400 etc etc
here some facts....
THE aftermarket is geared towards....T400, not 727's
COnverters, parts etc are all cheaper and more readily available for this trans, because almost everyone out there is using it.
Don't let your feelings get in the way....lol
honestly, a Rossler t400 may be overkill, but guess what, it will be THE LAST TRANS HE EVER BUYS.....keep up with fluid changes and it will literally last forever. I have a Rossler T400 for over 10 years, and still going strong. I make 915 on motor and 4-500? of nitrous on top
Clanton, to put a T400 in an A body, I fabbed a crossmember between my frame connecters. On the original crossmember, the part that passes above the trans I cut that back for clearance and fabbed a 16 ga flat steel to box it back in. Depending on how much cage you have that may not be necessary.
Any more questions ask, I did not do anything to the trans tunnel itself other than trim the lip where the floor and the firewall meet.
Hope this helps
PS : You made a great choice for a trans/trans builder, good luck
....BAD A$$ STREET CAR.....
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2762256
04/10/20 11:32 AM
04/10/20 11:32 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Rossler is a fantastic trans great choice, I agree you won't ever need another trans. May I also suggest a PPP shifter it will make your life easier for sure. Share some pics as you go through the process.
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2762263
04/10/20 11:45 AM
04/10/20 11:45 AM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Did you lower the engine in the chassis? I mocked a 400 up in my 66 Coronet with an Ultra bell and it was not going to fit without making the tunnel bigger. I couldn't lower the engine because of the oil pan and headers so I scrapped the idea and went with a 727 I just didn't want to get into that much work. I had a simialer situation with my 65 although the engine is further forward the firewall wasn;t so much the issue as the tunnel from there back. Again both were gen 3 hemi conversions and the pan and headers limited the amount I could lower the engine. Just curious what you did to get it to fit without cutting the tunnel up. Also I agree the 400 can be just as fast as a 727 expecially when you consider the gear ratio options with the 400. I had a 210 Rossler in the purple Challenger I bought from Steff that car would go crazy sometimes and that 210 Rossler really got it under control. Also for the nah sayers I tested with a 727 vs a 400 in that car..............the 400 was faster mainly because of gear ratio and the ability to control wheel speed vs the 2.47 low gear in the 727. I know the purests here will not like that but it is the truth.
here some facts....
Hope this helps
Re: TH400 to RB in 69 b body info [Re: biff426] #2762267
04/10/20 12:10 PM
04/10/20 12:10 PM
N
n20mstr Offline
n20mstr  Offline
N
[quote=biff426]
[quote=n20mstr]
I use a motor plate, I really cant say why, but it fits my trans tunnel no problem.?? It is an A body not a B ,
I was surprised myself that it fit pretty well .
Im computer illiterate, so if anyone wants pics โ€ฆ..text me your cell and what you want to see, I can text pics..LOL
my number is 914 417 1312
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2762288
04/10/20 12:45 PM
04/10/20 12:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The th400 from the bell back is just an 8" tube so I will test fit a tube to check the depth how it fits.I have 1" all around my 727 front to back so I think I may get lucky and only have to flat the tunnel lip to the fire wall.Thank you so much for your info!
here some facts....
Hope this helps
Re: TH400 to RB in 69 b body info [Re: n20mstr] #2762325
04/10/20 01:49 PM
04/10/20 01:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
here some facts....
Hope this helps
I agree the Rossler is a very nice piece. I don't care if its GM or Mopar. If you were starting wth nothing and making BIG power I see the logic. What I don't understand in this case is someone gave up at 30 passes with a trans that easily would've worked. By the time this is all said and done it'll be way over $5K. Now I don't know about everybody but spending $5K+ is a pretty big bite. Especially when what you already have would've easily worked. You tell me. How many low 10 second cars kill a 727 every 30 passes? My 727 has stranded me once in 7 years (635passes). Every pass 9.2x or better@3350 or more. It was an aftermarket part design failure which was easily corrected. My trans in my sons turbo car with a 727 using a brake at 3750lbs (9's at 136 -142) has only stranded once as well in over 5 years. Easy upgrade to fix it as well. Just my 2cents
Doug
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762349
04/10/20 02:47 PM
04/10/20 02:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I took some measurements off my friends th400[width,length,height from pan rail] and I will compare it to my spare 727.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762352
04/10/20 02:56 PM
04/10/20 02:56 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I am getting ready to make the move to a TH400 in my Satellite.I asked in the past for a pic of the trans tunnel adjustment but never got it so if you have 1 please post it along with the trans cross member.I am going with an Utra bell because I don't want a mid plate if I can.TIA for your help!
Ohhhh my God, Chevy transmissions. Whatโ€™s next ford 9 inch rearends. We canโ€™t even get our guys to give up 50 years old technology and update their radiator FLEX hoses and screw clamps. Lmao. Hemi guys included.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: TH400 to RB in 69 b body info [Re: dvw] #2762358
04/10/20 03:01 PM
04/10/20 03:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have 2 transmissions that I went through 3 rebuilds 2 on 1 and 1 on the other.Not just 1 trans 30 runs.Maybe that is not enough for you but it was me and here we are.just an fyi!
here some facts....
Hope this helps
Doug
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762367
04/10/20 03:20 PM
04/10/20 03:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The 727 is wider than the th400 from bell to tail housing basicly.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2762403
04/10/20 04:30 PM
04/10/20 04:30 PM
I had forgot about you using the blower, power will find all the weak parts blush
Re: TH400 to RB in 69 b body info [Re: Cab_Burge] #2762915
04/12/20 02:06 AM
04/12/20 02:06 AM
CALIFORNIA
X9 X3 R/T Offline
X9 X3 R/T  Offline
CALIFORNIA
I don't really post at all, but I have run a 400 transmission in my 68 charger for a couple of years.
I recently removed it only because the car went to fast for the 5 point bar in the car.
It really is not that big of a deal to make fit. If your car is tied by frame connectors like mine is,
we cut the transmission crossmember to the center of the mounting bolts on each side. Then drilled out the
spot welds and made our own crossmember from rectangular tubing. It will put he transmission down about 3 degrees
lower than stock, but I was able to correct it with wedges under the axle. We never cut the factory tunnel.
It really is a sweet setup. I never experienced any vibration on the street or at the track. It easily stood up to a 498 wedge with
440-1 heads, 12.3 compression and a big shot plate system. With a 3800 Continental converter and manual valve body it really
was a great combo. Leaving on the transbrake with the unit the 1st time scared me straight. It also got me kicked off of all the
local tracks I can go to.
I returned the car back to the original 4 speed because I'm sill
a mopar [censored] at heart. And because racing a full size b body takes a lot more money than I'm willing to spend on a car I'd rather
drive
Call me if you have any questions 626 675 0664 pst
BTW, I still have the complete setup soup to nuts including the driveshaft and oil cooler if you do not have one already sourced.
Mike
Re: TH400 to RB in 69 b body info [Re: X9 X3 R/T] #2762921
04/12/20 03:56 AM
04/12/20 03:56 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
maybee hes like some of us that had 727 bomb go off,i still dont trust a 727 no matter who builds it
Re: TH400 to RB in 69 b body info [Re: dart games] #2762935
04/12/20 08:19 AM
04/12/20 08:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by 69b1dart
maybee hes like some of us that had 727 bomb go off,i still dont trust a 727 no matter who buils it
Simple answer. Aluminum drum.
Doug
