Big block timing cover, for serious cam thrust?
#2774819
05/15/20 12:27 PM
05/15/20 12:27 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Years ago i went to a geardrive to control cam walk. I was using a standard type timing cover and thrust button. The cam actually distorted the cover and was running so far out it almost crashed adjoining lobes into the next lifters. It took a lot of pressure to do that . After battling many rocker bearing failures for years i am forced to try another stock type cover and chain in hopes that that will eliminate harmonics that may be destroying my rockers. Does anyone make a renforced cover, or has anyone come up with a solution to this problem? I don't want to spend 1250 for a belt drive. My race budget is real tight right now.
Re: Big block timing cover, for serious cam thrust?
[Re: gregsdart]
#2774822
05/15/20 12:30 PM
05/15/20 12:30 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ve used the cast aluminum Indy covers for years with zero issues
[Re: gregsdart]
#2774824
05/15/20 12:32 PM
05/15/20 12:32 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
I have seen people put a wedge between the timing cover and water pump...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2774825
05/15/20 12:35 PM
05/15/20 12:35 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
ATI offers a whim that Summit stock if your damper needs spaced out.
[Re: gregsdart]
#2774844
05/15/20 01:09 PM
05/15/20 01:09 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
Sounds like there is a issue with the lifter bore angles not being correct causing to much pushing by the roller lifters trying to force the cams forward Very common on BB Chevy motors, not so much on BB Mopars or 426 hemi motors
[Re: AndyF]
#2774874
05/15/20 03:03 PM
05/15/20 03:03 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Just curious why you are not considering a belt drive???
[Re: rickseeman]
#2774883
05/15/20 03:34 PM
05/15/20 03:34 PM
Al_Alguire
Las Vegas
Missed that last sentence, but they are out there in the secondary market. I have purchased three in the last year that way, and if you have an issue with cam thrust Jesel also offers a solution for that with their belt drive with their zero thrust cam adapters. Been there done that.
[Re: W.I.N. Racing]
#2774899
05/15/20 04:34 PM
05/15/20 04:34 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I have seen people put a wedge between the timing cover and water pump... I had to do that very thing once. I believe the force was coming from the oil drive. I welded a nut on the back of the waterpump and had a bolt in it to run agains the timing cover. Roller bearing thrust button. The timing would swing wildly as it pushed forward, essentially turning the distributor location as it moved forward.
[Re: Al_Alguire]
#2774922
05/15/20 05:29 PM
05/15/20 05:29 PM
Posts: 31,074 Oregon
AndyF
Missed that last sentence, but they are out there in the secondary market. I have purchased three in the last year that way, and if you have an issue with cam thrust Jesel also offers a solution for that with their belt drive with their zero thrust cam adapters. Been there done that. I think I might have sold you a slightly used Jesel belt once or twice! I used to buy them for my dyno engines and then sell them once the testing was done since most people weren't interesting in buying a pump gas engine with a Jesel belt drive. If I was running a serious race engine I'd use a belt drive. Lots of advantages with the belt drive including the super nice setup for camshaft endplay as well as the ease of indexing the cam.
[Re: Dodgeguy101]
#2774981
05/15/20 09:30 PM
05/15/20 09:30 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I started welding 1/8 plate on my stock covers
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
