Re: Critique this engine combo, carb'd 5.2
[Re: 73DAD]
#2774453
05/14/20 10:25 AM
05/14/20 10:25 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
One thing that stands out to me already is I would use a thinner head gasket. Assuming your short block has stock pistons and the deck has not been cut, Mr. Gasket .028 thickness would give you a little compression bump. You might also consider a regrind cam and save a couple hundred bucks.
[Re: mgoblue9798]
#2774473
05/14/20 11:33 AM
05/14/20 11:33 AM
Posts: 9,836 MI, usa
dvw
MI, usa
Just did this with a 5.9 magnum. Many aftermarket hyd rollers have extended nose that allows for the stock LA fuel pump eccentric. Eddy heads use a longer push rod than stock. You'll need a 45 degree pipe fitting to adapt the Magnum bypass hose outlet to the LA water pump. You may have to shim the left motor mount bracket, ear distance is different. You can bend the throttle linkage to fit the magnum intake. https://www.forbbodiesonly.com/mopa...build-how-i-do-it.187572/#post-911485726Doug
[Re: dvw]
#2774515
05/14/20 01:50 PM
05/14/20 01:50 PM
Posts: 313 Northeast Indiana
73DAD
Northeast Indiana
Just did this with a 5.9 magnum. Many aftermarket hyd rollers have extended nose that allows for the stock LA fuel pump eccentric. Eddy heads use a longer push rod than stock. You'll need a 45 degree pipe fitting to adapt the Magnum bypass hose outlet to the LA water pump. You may have to shim the left motor mount bracket, ear distance is different. You can bend the throttle linkage to fit the magnum intake. https://www.forbbodiesonly.com/mopa...build-how-i-do-it.187572/#post-911485726Doug Thanks a ton, sounds like a lot of that information was earned through trial & error, I appreciate you sharing that stuff freely. I've built big blocks & Hemis, but this is my first venture into small-block territory. I quoted an .047 gasket because... that's just what comes with the cheap fel-pro gasket kit. I wouldn't be above getting a pair of .027 cometics, but it is supposed to be a relatively low buck build. I haven't bought anything yet, just laying out my parts list.
[Re: 73DAD]
#2774777
05/15/20 10:41 AM
05/15/20 10:41 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I'd use a 5.9 Magnum instead of the diminutive 5.2.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2774831
05/15/20 12:49 PM
05/15/20 12:49 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I'd use a 5.9 Magnum instead of the diminutive 5.2. The 318 mag has more compression and tighter quench, flat piston for better flame travel and less heat soak so the power difference is very small in reality. That said you will make a hair more with a 5.9 but they are not far apart when running stock short blocks.
[Re: jbc426]
#2774843
05/15/20 01:08 PM
05/15/20 01:08 PM
73DAD
Northeast Indiana
I'd use a 5.9 Magnum instead of the diminutive 5.2. I was under the impression that all 318's and 5.2's are internal balanced while 5.9's and 360's are external balance. If I swap to a 5.2 I can use the flywheel from my 318.
[Re: 73DAD]
#2774902
05/15/20 04:38 PM
05/15/20 04:38 PM
Guitar Jones
I'd use a 5.9 Magnum instead of the diminutive 5.2. I was under the impression that all 318's and 5.2's are internal balanced while 5.9's and 360's are external balance. If I swap to a 5.2 I can use the flywheel from my 318. You are correct. I would caution you that you can't put to much of a cam in the 5.2 magnum with the stock pistons without running into valve to piston problems. I don't know what the specs on that cam are but anything over .470 lift with 212@.050 is probably going to be a problem and that is with the stock .050 or so head gasket. Remember that most of those aftermarket cams are listing the lift figures with a 1.5 rocker and magnums use a 1.6 rocker. Edit: I just looked up that cam and while it does say it's for the 1.6 rocker ratio i don't think it will fit with .506 lift and 216/224 duration @ .050.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
