manual transmission ??? #277446
04/05/09 12:35 AM
04/05/09 12:35 AM
wine valley
cudaben1968 Offline OP
wine valley
real quick guys, its a honda but i figure all trannys are similar. I have a 5 speed manual trans that pops out of second gear just crusing.... synchro spring? or synchro sleeve? thanks
Half measures availed us nothing. We stood at the turning point. -Alcoholics Anonymous, The Big Book
Re: manual transmission ??? [Re: cudaben1968] #277447
04/05/09 02:44 PM
04/05/09 02:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Probably a combo of a few things,second gear clutching teeth take a real beating and so does the slider/syncro.I would change the gear,all the brass and the slider.
Gus
64 Plymouth Savoy
Dana 60
Re: manual transmission ??? [Re: cudaben1968] #277448
04/05/09 03:48 PM
04/05/09 03:48 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
My 833 was doing this and when I took it apart to rebuild it the syncro was actually broke in two pieces.
I've also seen this happen when the mechanism isn't adjusted properly. My buddy had a ton of problems and we found out his stops weren't letting the shifter go far enough for the detent ball to fall into place
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: manual transmission ??? [Re: DemonDust] #277449
04/05/09 07:39 PM
04/05/09 07:39 PM
wine valley
wine valley
ok thanks guys, ill pull it apart tomorrow ansd see what it looks like.
