70 Challenger Shut Off While Idling
#2774345
05/13/20 08:47 PM
05/13/20 08:47 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Car shut off while idling in the driveway:
I planned on taking the car out this weekend for the first drive of the Spring. I wanted to get the engine up to temp and then shut it off for a few minutes and then test the warm restart. I just replaced the battery cable and wanted to see if it made any difference.
So I started up the car and pulled it out of the garage and while it was warming up, I had all of the lights on so I could watch and see if there were any charging issues while I cleaned out the garage. About 20 minutes later, I approached the car to get it in and pull it into the garage. The car just shut off! No sputtering, the lights were all nice and bright. It just shut off. I was suspecting a fuse but I noticed that all of the lights were nice and bright (just like if the engine was running), the electric fuel pump was still running, and both of the A/F gauges were still active, the dash lights were still on. I grabbed my meter and quickly checked the battery voltage (with everything still on) it showed 12.53v at the battery. So then I turned the key off. After about 5-7 minutes of thinking about it, I leaned in and turned the key (just to see what would happen) and the engine fired right back up just as quick as it shut off. The good news is, the new battery cable worked out great on a hot restart! So then I immed iatlely pulled the car back in the garage and shut it off.
It appears that the battery, alternator, fuel are all in good working order. I am assuming the since the car was idling, the ignition must have lost voltage. But it re-started like a champ and the ignition box had a solid red light.
I plan on chasing the wiring from the MSD Streetfire box back to the battery. Then follow the RUN wiring from the box back to the steering column.
What else would you suggest to look at? (Ignition switch shorting out?)
Thanks! Dave
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: 70 Challenger Shut Off While Idling
[Re: YO7_A66]
#2774465
05/14/20 11:02 AM
05/14/20 11:02 AM
Posts: 19,406 north of coder
moparx
look the bulkhead connections over good for any signs of corrosion or damage, also check the ignition switch connection at the base of the steering column for the same. you mentioned the ignition box indicator glowing. check the blue and brown [crank and run] power to the box wires to their bulkhead connections, as well as from the bulkhead to the ignition switch. i'm just guessing the MSD street fire box is wired similar to a 6AL in that the ballast resistor is bypassed ?
[Re: YO7_A66]
#2774496
05/14/20 12:57 PM
05/14/20 12:57 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Until it does this more than once I wouldn't worry about it......
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2774500
05/14/20 01:12 PM
05/14/20 01:12 PM
RapidRobert
take out the idle mixture screws & shoot a good blast of brake kleen into both of the ports. before removing them 1st count the # of turns into lightly seated so you can quickly return them to their exact positions when done
[Re: RapidRobert]
#2774649
05/14/20 08:18 PM
05/14/20 08:18 PM
YO7_A66
Indiana
Thanks for the replies.
I need to find out why this happened. I dont want to be stranded out with the kids.
The carb was taken apart over the Winter and all air/fuel holes were blown out with carb cleaner and I put new gaskets where needed. I dont think it is a carb problem since it shut off like a light switch.
I chased the 12v battery wire tonight and tightened a few connectors, but I did not find anything obvious. I then checked the distributor connections and found one a little looser than I liked. So I got that connector tightened up and then heat shrunk the dist connector to make sure that it does not vibrate loose.
Saturday I will chase the 12v RUN wire back to the column. I picked up a new ignition switch today and will start that swap this weekend. I am now wondering if my hot engine-slow crank issue and this shutting down at idle issue are both related to the ignition switch.
Thanks again!! Dave
[Re: YO7_A66]
#2774675
05/14/20 09:36 PM
05/14/20 09:36 PM
Posts: 2,094 central texas
krautrock
central texas
I would check the 12v switched signal to the ign box. BUT, i have an MSD streetfire on my truck, the light doesn't turn on with the 12v switch. it signals from the reluctor/pickup coil in the distributor. just dbl checked, turned my ign on, motor not running, the light wasn't on. turned it over without pumping the gas so it wouldn't start (bowls are a little empty) and i could see the light flashing. engine running the light is just solid.
[Re: YO7_A66]
#2774680
05/14/20 10:22 PM
05/14/20 10:22 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
This may very well be a ignition or current contact issue, I would start it and let it idle and watch it for at least 20 to 30 minutes to see if it will do it again If it does stop have your electrical test tools handy and start looking at the ignition feeds and voltages, it, the ignition feed to the box or coil, may be heating up and going open (AKA as a high resistance open or high joint), no electron flow Good luck, let us know what you find, BTW how good are all of your grounds?
[Re: Cab_Burge]
#2775058
05/16/20 09:57 AM
05/16/20 09:57 AM
YO7_A66
Indiana
""I would check the 12v switched signal to the ign box. BUT, i have an MSD streetfire on my truck, the light doesn't turn on with the 12v switch. it signals from the reluctor/pickup coil in the distributor. just dbl checked, turned my ign on, motor not running, the light wasn't on. turned it over without pumping the gas so it wouldn't start (bowls are a little empty) and i could see the light flashing. engine running the light is just solid.""
I just double checked mine too and it is the same as yours. Key to RUN and no light at the box. Crank and it shows flashing light. I mentioned previously that I found a couple of loose connections under the hood but I did not say which connections. One was the large RED wire at the battery. The connector came apart a little easier than I would like but I think it was good, but I tightened it up. The second loose connector was the distributor connector. It slid apart easily, so I tightened it up and then taped it together and now it is tied together. This may have been the issue.
I just checked the voltage for the RUN at the steering column connection (my new connection that bypasses the connector and goes to the MSD box) and it was tight, heat shrunk, and showed 12v with the key in the RUN position. I stripped off the heat shrink and I am letting it stay uncovered so that I can use it as a 12v RUN check if this happens again. Thank You!!
Cab: When the car shut off at idle, I did not have any good places to check the RUN voltage at that time because they are all heat shrunk. As just mentioned, I uncovered the one under the dash and I will use it it this happens again for a check point before shutting off the key.
I am going to do another test at idle and I will check back in.
Thanks again!! Dave
[Re: fourgearsavoy]
#2775280
05/16/20 11:54 PM
05/16/20 11:54 PM
Posts: 1,755 Phila
PhillyRag
Phila
With the slow crank you might want to install another ground from the engine to the chassis and see if that helps. As for the engine dying that could be a coil winding opening up when it gets hot. If you have another known good one I would swap it out Gus Also check resistance of the dist. pickup coil. Had one years ago that would lose continuity after running for a while. When cooled off, would make contact again to run. Next time it died I check leads & found "open circuit". The coil has a range of ohms that are acceptable: check your ohms (maybe hot & cold). Could give you another avenue to pursue
[Re: YO7_A66]
#2775458
05/17/20 03:12 PM
05/17/20 03:12 PM
Cab_Burge
It sounds to me that you have enough grounds if the wire gauge are big enough, what gauge are the other additional grounds?
[Re: Cab_Burge]
#2775565
05/17/20 07:57 PM
05/17/20 07:57 PM
YO7_A66
Indiana
Cab, All of the battery grounds are of stock size. The starter and the alternator grounds are 10ga.
After doing some reading, I found a 3/8-16 tapped hole on the drivers side block just above the oil pan. I took an old 1ga negative battery cable and bolted one end to this tapped hole on the block and the other end down on the sway bar mounting bracket.
If this does not help, I may be looking at trading in the 5 year old battery for an upgrade. The coil is a 2 year old MSD Vibration coil.
Thanks again! Dave
