Re: Maybe the ultimate first gen dodge rear differential?
[Re: Uberpube]
#2773993
05/12/20 08:09 PM
05/12/20 08:09 PM
Posts: 21,517 in a cattle trailer down by th...
Guitar Jones
Pretty cool and probably cleaner than my disc swap. I just used brackets from Great Lake Off Road, Cut the spacers from tubing and used 3/4 ton GM front calipers and rotors. You can use Eldorado calipers for a parking brake but I just used a circle track hydraulic brake cut off valve (it's basically just a ball valve) in the rear brake line to use for a parking brake, works very well and it's tons cheaper than the Eldorado calipers, if you can even find them. Now you need a hydroboost.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Uberpube]
#2799259
07/21/20 08:03 AM
07/21/20 08:03 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: 360view]
#2800764
07/24/20 07:32 PM
07/24/20 07:32 PM
Posts: 6,669 ohio
ruderunner
ohio
I never had the opportunity to put them side by side but, I believe that front calipers from a 97 E250 are the same as the 2nd gen dually disc rear calipers.
The brackets are different for sure but that's the difference between a knuckle and axle tube.
Angry white pureblood male
