Blower resistor-83 Ram 4163688 #2771848
05/06/20 04:21 PM
05/06/20 04:21 PM
stratford,ontario,canada
JD340 Offline OP
JD340  Offline OP
So I'm quickly learning that these are hard to come by. I searched the usual places online, local yard doesnt have anything older than an 87 Ramcharger, local parts houses are coming up empty as well. Google search turned up old auctions on Ebay but nothing current. Anyone know where I can find a new one? Or a known good used one? Any help is appreciated as always! up
Nothing to see here. Carry on.
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2772003
05/07/20 08:15 AM
05/07/20 08:15 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
The '87 Ramcharger should have the same one.
1981 Dodge D150 360 auto
Re: Blower resistor-83 Ram 4163688 [Re: basketcase] #2772113
05/07/20 02:22 PM
05/07/20 02:22 PM
JD340 Offline OP
JD340  Offline OP
I checked 3 Rams and 1 Ramcharger at the local yard yesterday, years ranged from 87-93. NONE were the same as mine. They all had a single molded plug and different terminal layout, and mounted right in the cowl. Mine mounts on top the heater box. I also checked a couple mid 80s Fifth Aves, also different. The only car at that yard that might have one the same as mine was an 80 Volare. I would've had to disassemble half the dash to get to it and I didn't bring enough tools with me to do so.
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2772115
05/07/20 02:25 PM
05/07/20 02:25 PM
JD340 Offline OP
JD340  Offline OP
Other than Ebay, I've checked Arizona Parts and Brad's NOS. Any other NOS sellers I should check into? I'm guessing this is my only choice, unless I can find a working used one.
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2772141
05/07/20 04:04 PM
05/07/20 04:04 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
How bad do you want one? A quick ebay check shows one, for a mere $100 simoleons. For that I might go pull the one out of my '85.
Edit Just noticed your location, is yours a/c or non a/c?
Either way, the ebay one is listed with that number.
It takes gasoline to interest me.
Re: Blower resistor-83 Ram 4163688 [Re: VL21] #2772156
05/07/20 04:40 PM
05/07/20 04:40 PM
JD340 Offline OP
JD340  Offline OP
I did see that one ebay today as well. I'm gonna take a chance on one for a 79-85 van. Looks identical to mine but a different part#. Best part? Only $30 and being shipped from Ontario only a few hours away from me. Fingers crossed it does the job or I might have to pony up for that $100 one. tsk
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2772513
05/08/20 03:43 PM
05/08/20 03:43 PM
JD340 Offline OP
JD340  Offline OP
Well I got a call back about 10 minutes later...already sold. Website just wasn't updated. Darn!
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2773150
05/10/20 11:58 AM
05/10/20 11:58 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Do you have a picture?
Re: Blower resistor-83 Ram 4163688 [Re: 77ProStreet] #2773225
05/10/20 03:33 PM
05/10/20 03:33 PM
JD340 Offline OP
JD340  Offline OP
Let's see if this works...
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2773332
05/10/20 09:10 PM
05/10/20 09:10 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
looks the same one that's been in my '81,85,85,87,88,89,and '91. behind the glove box door on the heater.
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2773457
05/11/20 10:52 AM
05/11/20 10:52 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
$10 available on RockAuto...
Standard Motor Products RU485.
https://www.rockauto.com/en/moreinfo.php?pk=1513276&cc=1085868&jsn=606
Just my $0.02... wink
Re: Blower resistor-83 Ram 4163688 [Re: Sinitro] #2773569
05/11/20 03:45 PM
05/11/20 03:45 PM
JD340 Offline OP
JD340  Offline OP
Close. I should've taken my topside pic on more of an angle. On the left there are two horizontal terminals, and one vertical. They all plug into one plug. The terminal to the right has a single wire going to it.
Re: Blower resistor-83 Ram 4163688 [Re: basketcase] #2773572
05/11/20 03:52 PM
05/11/20 03:52 PM
JD340 Offline OP
JD340  Offline OP
The oldest one I could find in a local yard was an 87. It mounted directly in the cowl as opposed to in the heater box. It also had I think 5 or 6 terminals that connected to a single molded plug. Mine has a 3 terminal plug and one single one. I should just pick one of them up from the yard and try it just for giggles. Pop my terminals out of the plug and to make a newer one work. A guy on a facebook group has also success soldering in a new diode on his with good results. Maybe I'm just being a cheapskate, but $80-100+ for an NOS one is a hard pill to swallow for me. shruggy
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2773580
05/11/20 04:18 PM
05/11/20 04:18 PM
So Cal
So Cal
If something is slightly different...
Why take the resistor coils from the new part and solder onto your present part.
Pretty straight forward..
The other solution would be to jumper over your present defective resistor coils so now the full 12V is connected, U will lose the (2) lower speeds but still have the fast speed.
Re: Blower resistor-83 Ram 4163688 [Re: Sinitro] #2773610
05/11/20 05:24 PM
05/11/20 05:24 PM
JD340 Offline OP
JD340  Offline OP
Currently have a line on a used one, and a couple sources for NOS ones. My current one does still work...on high only. I think I've got this squared away. I'm just getting back into the hobby after a 10+ year hiatus. I guess I've got a bit of sticker shock when it comes to NOS prices. My old girl will just take a little longer to source parts for than it used to. Thanks for all the help everyone! up
Re: Blower resistor-83 Ram 4163688 [Re: JD340] #2773682
05/11/20 09:14 PM
05/11/20 09:14 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Get ready, sticker shock is a new daily experience. The next thing your going to learn is that quality no longer exists, and just because a part is new, that doesn't mean the part is good!
Old cars and trucks are fun they say....Have fun. Gene
Re: Blower resistor-83 Ram 4163688 [Re: poorboy] #2773919
05/12/20 03:52 PM
05/12/20 03:52 PM
JD340 Offline OP
JD340  Offline OP
You're not wrong Gene! After my time away from the hobby I'm learning that fast. Being north of border doesn't help either. With a weak dollar right now, it hurts the wallet that much more. After lots of searching, I found an NOS one for $40 shipped. Got another used one on it's way as well. Time to start hoarding this again like I used to. beer
