How fast/quick with single 800 Eddy #2773818
05/12/20 10:25 AM
05/12/20 10:25 AM
CT
roadrunner2 Offline OP
CT
Running just a single 800 Edelbrock carb due to rules. What have you run ET and MPH wise with just 800 cfm? I’m in a 3400 lbs race weight Road Runner
Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’
Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST.
10:1 451” replaced with 14:1 499”.
Re: How fast/quick with single 800 Eddy [Re: roadrunner2] #2773856
05/12/20 12:12 PM
05/12/20 12:12 PM
AndyF Offline
AndyF  Offline
If an 800 cfm carb and 3400 lbs are the only constraints then you should be able to run 10's without any problem. Maybe even faster. I used to watch Bob Mazzolini's Sebring run low 10's with a 9:1 compression 318, cast iron heads and QJet carb. The Sebring weighed 3200 lbs. Most people will tell yo that you can't run low 10's with a 9:1 318 and a QJet carb but he did it round after round. All depends on how much money you're willing to spend and how good you are.
