Richmond 5-speed floor clearance #2773611
05/11/20 05:25 PM
05/11/20 05:25 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
Looking into putting a Richmond into a 4-spd E-body, car already has the 4-spd hump.
I have been told by one fellow that the Richmond + linkage all cleared his 4-spd '70 Cuda with no messaging necessary.
I did not see this with my own eyes, and have heard stories just the opposite, but I don't remember the details
and it might not have been an E-body.
Anyone have E-body experience with the Richmond ?
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2773621
05/11/20 05:57 PM
05/11/20 05:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
AndyF might best answer this. bump
Re: Richmond 5-speed floor clearance [Re: jcc] #2773677
05/11/20 08:58 PM
05/11/20 08:58 PM
AndyF Offline
AndyF  Offline
Fairly major modifications are required to put a Doug Nash into a B body and I doubt that an E body would be any easier. The torsion bar crossmember needs to be cut and reworked and the floor needs to be modified.
Re: Richmond 5-speed floor clearance [Re: AndyF] #2773691
05/11/20 09:53 PM
05/11/20 09:53 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
IIRC the shifter for an E-body is farther rearward on the tailshaft than a B. I think in order to have straight shift rods you will have to move some metal around. If you have noodle shift rods you might get away with minor floor pan surgery. I know that the GF5R (same dimensions) in my '66 B-body required floor pan and torsion bar cross-member modification to fit correctly and retain good drive line angles. G Force will rent you a case to use for mock up if you call them up.
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2773732
05/12/20 12:22 AM
05/12/20 12:22 AM
AndyF Offline
AndyF  Offline
Look at the two transmissions side by side and tell me how you're going to fit that in a Mopar with making some serious modifications to the floor?
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2773786
05/12/20 09:06 AM
05/12/20 09:06 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have to ask the obvious question is he installing a 4 speed or a 5 speed??? The 4 speed is based on a Super T-10 while the 5-speed is based on a Doug Nash design. Which one is he doing to use?
I have recently rebuilt a Richmond 5-speed for a friend and he has it in a HEMI powered Cuda. The torsion bar crossmember needs to be modified and you also need to make a custom shifter mount to move the shifter up and back past the crossmember. You also have to fab up tome custom bent linkage to clear the crossmember.
I still have your number so I can text you a picture of the linkage and shifter mount in my phone.
If he is using a 4-speed then it will be an easier install but the shifter position and linkage will still be tricky to engineer twocents
I will try to get the pics to load on my computer.
Oh yeah he will also need a longer driveshaft with a T-400 yoke on it. I used a Spicer 1350 Chevy dump truck yoke for mine.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Richmond 5-speed floor clearance [Re: AndyF] #2773787
05/12/20 09:06 AM
05/12/20 09:06 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Andy's picture really exemplifies the issue we are discussing with fitment. As you can see the shifter cannot be moved any farther forward and where it is in the path of the t-bar x-member. The wider case also will require tunnel modifications and it takes a little work to get the floor pan contoured so that it does not intrude into the pedal box area (I like my roomy b-body lol).
Re: Richmond 5-speed floor clearance [Re: fourgearsavoy] #2773806
05/12/20 10:02 AM
05/12/20 10:02 AM
Washington
Washington
Fourgear, We are talking about the 5-speed.
Thanks guys, the pictures are helpful.
Is the E-body tunnel in fact the same as the B-body in the same model year ?
I thought maybe some of the clearance issues were from guys trying to put the 5-spd into a 727 car,
but evidently even the 4-spd cars need work.
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2773858
05/12/20 12:17 PM
05/12/20 12:17 PM
AndyF Offline
AndyF  Offline
A Richmond 5 speed will not fit in an E body car without significant modifications regardless of what someone tells you. Just lay under the car and look at the space and you'll understand the issue.
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2773887
05/12/20 01:34 PM
05/12/20 01:34 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The 66-70 B body and 70-74 E Body used the same length torsion bars. That tells us that the engine/trans is in the same place with respect to the torsion bar x-member so that is I why I assume you would have to modify your car similar to my Charger. The only difference between an automatic tunnel and a four speed tunnel is the factory cut a hole and added this:
http://www.brewersperformance.com/proddetail.php?prod=FT160
On my car I cut the spot welds off of the shifter box and moved it up and back on the tunnel. Non-four speed people don't even notice that the shifter is in the wrong (improved) location.
Re: Richmond 5-speed floor clearance [Re: Jeremiah] #2774060
05/13/20 01:14 AM
05/13/20 01:14 AM
AndyF Offline
AndyF  Offline
Correct, the T bars are the same and the K frame is the same between E and B body cars so the trans tunnel is probably the same or very close to being the same. I think the transmission mount and crossmember interchange also.
Re: Richmond 5-speed floor clearance [Re: AndyF] #2774097
05/13/20 08:39 AM
05/13/20 08:39 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Thank you for confirming that Andy.
Re: Richmond 5-speed floor clearance [Re: fourgearsavoy] #2774102
05/13/20 08:52 AM
05/13/20 08:52 AM
Washington
Washington
FourGear,
Still thinking about this, I can't mock anything up yet.
Your friend with the hemi Cuda, even with modifying the T-bar crossmember he also had to relocate the shifter on the tranny ?
If you have those pics, can you send to 206-255-6644 ?
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2774115
05/13/20 09:35 AM
05/13/20 09:35 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
not sure if you can see these pics or not, if you can, this is probably the kind of stuff required for the Richmond 5spd also.
https://www.instagram.com/p/B_x5rdAFeZU/?utm_source=ig_web_copy_link
Re: Richmond 5-speed floor clearance [Re: krautrock] #2774224
05/13/20 02:18 PM
05/13/20 02:18 PM
Washington
Washington
Wow, [censored], that looks great, extremely helpful !
How did you make that big C-shaped brace ?
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2774228
05/13/20 02:23 PM
05/13/20 02:23 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
that's not mine, just someone i keep up with. looks like he welded lots of sections of tubing (maybe 1x2") to form the C in the tunnel.
anyways, it's extensive work. if you search google images for something like "mopar T56 swap" you can see images of what other people did.
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2774250
05/13/20 03:28 PM
05/13/20 03:28 PM
AndyF Offline
AndyF  Offline
This article might show you some of the fab work required. This is for a T56 which is even bigger than a Richmond but a lot of the information will apply.
https://www.hotrod.com/news/install-tremec-t56-6-speed-plymouth-duster-mopar/
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2774270
05/13/20 05:20 PM
05/13/20 05:20 PM
Rittman Ohio
Rittman Ohio
FourGear,
I sent you a pic of the shifter on the transmission with the bracket.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Richmond 5-speed floor clearance [Re: fourgearsavoy] #2774275
05/13/20 05:38 PM
05/13/20 05:38 PM
Washington
Washington
I got it, great picture.
If I go this whole route, I guess I can kiss a carpeted floor goodbye.
Re: Richmond 5-speed floor clearance [Re: hemienvy] #2774285
05/13/20 06:00 PM
05/13/20 06:00 PM
Rittman Ohio
Rittman Ohio
I have carpet in my Savoy it just doesn't fit too well, When I had my Long V-gate in the car with my Richmond I needed a BIG hole in the floor.
Gus beer
64 Plymouth Savoy
Dana 60
