Who sells e-body under rear seat pan sections?
#2771677
05/06/20 01:39 AM
05/06/20 01:39 AM
Posts: 37 SF Bay Area
cudabill
SF Bay Area
I need to replace a portion of a rear seat under pan, and don't want to spend $300-$450 for an entire section.
Who sells a portion of an under rear seat pan?
Current:'70 Barracuda 383 Gran Coupe project, Past highlights: Datsun roadster/Olds V8, Porsche 924/buick V6, '89 IROC-Z, '00 Vette/procharged LS3, ML63, 335i, 914, 944T, '39 LaSalle sedan project
Re: Who sells e-body under rear seat pan sections?
[Re: 469runner]
#2771961
05/06/20 11:40 PM
05/06/20 11:40 PM
cudabill
SF Bay Area
That's what I was hoping not to find out, I've seen the AMD price. The damaged section is the size of a griddle.
The entire section provides quite a bit of structural integrity and I don't need or want to replace the entire thing. Plus I'd cut it to fit around the mini tubs.
[Re: cudabill]
#2772368
05/08/20 08:42 AM
05/08/20 08:42 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
The entire section provides quite a bit of structural integrity and I don't need or want to replace the entire thing. Plus I'd cut it to fit around the mini tubs. Other option is to place a want ad here and see if someone has a section they could cut out. Or, since the area is pretty small, fins a metal worker in your area and fabricate it. With a bead roller you can duplicate the ribs. I've used ball peen hammer and made small repair sections to ribs.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2772697
05/09/20 03:19 AM
05/09/20 03:19 AM
cudabill
SF Bay Area
Thanks @RoadRunner, I might just order a bead roller and fab it.
I'm not afraid of a little work.
