Small Block Oil Pump Drive #2771660
05/05/20 11:32 PM
05/05/20 11:32 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
I know there is a new type of cam gear you can run on a roller cam (composite or coated iron) does anybody have a favorite? I need the complete drive (Shaft and gear). I was going to use a bronze gear but this engine is going to see a lot of street miles so I though I would ask about options.
Re: Small Block Oil Pump Drive [Re: Biginchmopar] #2771683
05/06/20 02:25 AM
05/06/20 02:25 AM
I ran the bronze gear on my old pump gas BB Duster for over 3000 miles and a lot of passes at the track with no issues I remember shruggy
I built that motor in the early 2000s also shruggy
Re: Small Block Oil Pump Drive [Re: Cab_Burge] #2771698
05/06/20 06:21 AM
05/06/20 06:21 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Maybe I am just lucky but I have had the same Bronze gear in two different engines with the same roller cam. No major wear or slop in it so far. Been using it since 08 or so. Not many street miles but quite a few passes down the track
6.50 @105.26
Re: Small Block Oil Pump Drive [Re: Kindafast] #2771729
05/06/20 09:36 AM
05/06/20 09:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bronze here. I still run one in my SFT engine on the road(hot rod I drive alot)
wave
