guy insists his 66 Coronet is pos ground.
#2771565
05/05/20 07:44 PM
05/05/20 07:44 PM
Posts: 4,848 Memphis
HemiRick
Memphis
We've got a new member of our local mopar club and he insists his 66 Coronet is pos ground. the pos cable is going to the block and the neg to the starter he says...Is he badly mistaken?...How is this possible?
Thanks for your thoughts Rick
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: guy insists his 66 Coronet is pos ground.
[Re: iapco103]
#2771575
05/05/20 08:18 PM
05/05/20 08:18 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I've had many P.O.S. grounds. Cleaned them up and that fixed them.
But in the case of this member, he needs to sell his 66 Coronet and buy a Chevy Chevette and call it a Vette.
Do you think he is that ignorant or just pulling your chain?
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: iapco103]
#2771585
05/05/20 08:23 PM
05/05/20 08:23 PM
HemiRick
Memphis
No I've not seen this car.....As to whats up I hesitate to speculate
[Re: 69gtxvert]
#2771589
05/05/20 08:27 PM
05/05/20 08:27 PM
HemiRick
Memphis
No I asked him to check this
[Re: HemiRick]
#2771590
05/05/20 08:28 PM
05/05/20 08:28 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
[Re: NITROUSN]
#2771600
05/05/20 08:52 PM
05/05/20 08:52 PM
HemiRick
Memphis
I gave him a link to this thread hopefully he will chime in
[Re: HemiRick]
#2771616
05/05/20 09:25 PM
05/05/20 09:25 PM
Posts: 10,749 North Dakota
6PakBee
North Dakota
There are a lot of people who believe a lot of things. Think of those who are convinced they were abducted by aliens and subjected to a body cavity search. You cannot convince them otherwise. In this case though, take a look at the car, that'll answer it one way or another.
[Re: HemiRick]
#2771637
05/05/20 10:37 PM
05/05/20 10:37 PM
Posts: 43,263 Bend,OR USA
Cab_Burge
Technically he is correct, all battery current flows from the negative (the hot side) post out on that lead and returns back to the positive side Basic Direct Current electricity If he has the negative cable hook to the starter and starter relay with the positive cable hook directly to the block he is not doing it (wiring) the way Mopar and most other American car manufacturers made them or designed the electrical system to work I'm almost sure that the diodes in the alternator won't allow it to charge with reverse polarity like generators will
[Re: Sniper]
#2771795
05/06/20 12:32 PM
05/06/20 12:32 PM
Cab_Burge
Would that mean that everything would also have to be positive ground and the starter motor would spin the opposite direction and have a positive ground radio, the wiper motor would turn the opposite direction and park on the other side, plus the heater/defroster fan would be turning the other direction and on and on and on??? There has always been a myth about Chrysler electrics being "different" so I think this guy has bought into something? Be careful how you break it to him, could get weird or dicey, social distancing rules apply here for sure Get, I better go out to my 51 and replace all those backwards running motors since I converted it from 6v positive ground to 12v negative ground. Funny thing is, they turn the right way with either setup. That be true, all American made 6 Volt cars since the beginning of when they where made had positive grounds, why they switch to negative grounds on 12V cars is still a mystery to me I'm thinking American made airplanes, both 12V and 28 V, are positive grounds Maybe not
[Re: Cab_Burge]
#2771799
05/06/20 12:43 PM
05/06/20 12:43 PM
Posts: 6,299 nowhere
Sniper
nowhere
why they switch to negative grounds on 12V cars is still a mystery to me : galvanic corrosion
[Re: Sniper]
#2772083
05/07/20 12:15 PM
05/07/20 12:15 PM
Posts: 12,437 Warren, MI
71TA
Warren, MI
Like mentioned above, many things would have to be changed for that to work. Even in such a simple electrical system as a 66 car; starter, alternator, radio, power window motors, etc. The points ignition would work with POS ground.
I'd bet money its not "really" a pos ground , an outright fib or like one of my college professors used to say, "involuntarily ignorant".
