guy insists his 66 Coronet is pos ground. #2771565
05/05/20 07:44 PM
05/05/20 07:44 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
We've got a new member of our local mopar club and he insists his 66 Coronet is pos ground. the pos cable is going to the block and the neg to the starter he says...Is he badly mistaken?...How is this possible?
Thanks for your thoughts
Rick
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2771566
05/05/20 07:50 PM
05/05/20 07:50 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
It's a requirement with the 318 hemi..........
hop
John
Re: guy insists his 66 Coronet is pos ground. [Re: SattyNoCar] #2771573
05/05/20 08:13 PM
05/05/20 08:13 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Have you seen this with your own eyes?
The only way this is possible is to have the battery charged in the opposite polarity. Before you say it can't be done, rest assured that it can. ( a lead-acid battery has to be drained to absolutely nothing and then the polarity can be reversed ).
If he has done this, it is a clever trick for attention. BUT..... it carries huge consequences if someone puts a different battery in the car. ( it will let the smoke escape from everything ). Paul
Re: guy insists his 66 Coronet is pos ground. [Re: iapco103] #2771575
05/05/20 08:18 PM
05/05/20 08:18 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I've had many P.O.S. grounds. Cleaned them up and that fixed them.
But in the case of this member, he needs to sell his 66 Coronet and buy a Chevy Chevette and call it a Vette.
Do you think he is that ignorant or just pulling your chain?
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: guy insists his 66 Coronet is pos ground. [Re: iapco103] #2771585
05/05/20 08:23 PM
05/05/20 08:23 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
No I've not seen this car.....As to whats up I hesitate to speculate
Take care,
Rick
Re: guy insists his 66 Coronet is pos ground. [Re: Dave_J] #2771587
05/05/20 08:26 PM
05/05/20 08:26 PM
Salem, NY
69gtxvert Offline
69gtxvert  Offline
Salem, NY
Probably red insulation on the negative ground cable.....
Re: guy insists his 66 Coronet is pos ground. [Re: 69gtxvert] #2771589
05/05/20 08:27 PM
05/05/20 08:27 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
No I asked him to check this
Take care,
Rick
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2771590
05/05/20 08:28 PM
05/05/20 08:28 PM
Guitar Jones Offline
He's a moron.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: guy insists his 66 Coronet is pos ground. [Re: Guitar Jones] #2771597
05/05/20 08:45 PM
05/05/20 08:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Tell him to post a picture of the battery and the cables.
Re: guy insists his 66 Coronet is pos ground. [Re: NITROUSN] #2771600
05/05/20 08:52 PM
05/05/20 08:52 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
I gave him a link to this thread hopefully he will chime in
Take care,
Rick
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2771616
05/05/20 09:25 PM
05/05/20 09:25 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There are a lot of people who believe a lot of things. Think of those who are convinced they were abducted by aliens and subjected to a body cavity search. You cannot convince them otherwise. In this case though, take a look at the car, that'll answer it one way or another.
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2771637
05/05/20 10:37 PM
05/05/20 10:37 PM
Technically he is correct, all battery current flows from the negative (the hot side) post out on that lead and returns back to the positive side scope
Basic Direct Current electricity shruggy
If he has the negative cable hook to the starter and starter relay with the positive cable hook directly to the block he is not doing it (wiring) the way Mopar and most other American car manufacturers made them or designed the electrical system to work shruggy
I'm almost sure that the diodes in the alternator won't allow it to charge with reverse polarity like generators will shruggy
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2771676
05/06/20 01:24 AM
05/06/20 01:24 AM
AndyF Online content
AndyF  Online Content
My advice is to not believe anything that guy tells you about anything. I think you'll be better off in the long run.
Re: guy insists his 66 Coronet is pos ground. [Re: AndyF] #2771694
05/06/20 05:31 AM
05/06/20 05:31 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
A wise man once said...
Earning every penny of that moderator paycheck.
DBAP
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2771756
05/06/20 10:57 AM
05/06/20 10:57 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Maybe it's a Packard Coronet? wink
Re: guy insists his 66 Coronet is pos ground. [Re: A12] #2771762
05/06/20 11:06 AM
05/06/20 11:06 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Would that mean that everything would also have to be positive ground and the starter motor would spin the opposite direction and have a positive ground radio, the wiper motor would turn the opposite direction and park on the other side, plus the heater/defroster fan would be turning the other direction and on and on and on??? There has always been a myth about Chrysler electrics being "different" so I think this guy has bought into something? Be careful how you break it to him, could get weird or dicey, social distancing rules apply here for sure grin
Re: guy insists his 66 Coronet is pos ground. [Re: A12] #2771781
05/06/20 12:00 PM
05/06/20 12:00 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Get, I better go out to my 51 and replace all those backwards running motors since I converted it from 6v positive ground to 12v negative ground. Funny thing is, they turn the right way with either setup.
Re: guy insists his 66 Coronet is pos ground. [Re: Sniper] #2771795
05/06/20 12:32 PM
05/06/20 12:32 PM
That be true, all American made 6 Volt cars since the beginning of when they where made had positive grounds, why they switch to negative grounds on 12V cars is still a mystery to me shruggy
I'm thinking American made airplanes, both 12V and 28 V, are positive grounds work
Maybe not shruggy
Re: guy insists his 66 Coronet is pos ground. [Re: Cab_Burge] #2771799
05/06/20 12:43 PM
05/06/20 12:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Cab_Burge
why they switch to negative grounds on 12V cars is still a mystery to me :
galvanic corrosion
Re: guy insists his 66 Coronet is pos ground. [Re: Sniper] #2772083
05/07/20 12:15 PM
05/07/20 12:15 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Like mentioned above, many things would have to be changed for that to work. Even in such a simple electrical system as a 66 car; starter, alternator, radio, power window motors, etc. The points ignition would work with POS ground.
I'd bet money its not "really" a pos ground , an outright fib or like one of my college professors used to say, "involuntarily ignorant".
