Fire suppresion system on car with no hood
#2770591
05/02/20 10:54 PM
05/02/20 10:54 PM
Posts: 7,479 Minnesota
Hemi_Joel
Minnesota
A guy I know had a crash and fire today. It got me thinking about installing a fIre suppression system in my car. Would it do any good to spray halon or whatever they use now at the engine of a car like mine? Wouldn't it all just blow away? What are the recommendations for a system that is light weight but effective?
Todays crash and
My car with no hood:
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Fire suppresion system on car with no hood
[Re: Hemi_Joel]
#2770620
05/03/20 01:10 AM
05/03/20 01:10 AM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That thing burnt for a while. How far did the fire crew have to come from? What caused the fire?
The Halon systems rely on displacing oxygen from a closed area to put the fire out. If you got caught inside of an area with Halon dumped in it, you would suffocate if you didn't get out. I stuck my head in car once that had the system discharged accidentally. Very strange experience.
It's not useful in the open, especially with the car moving. Even Top Fuel cars don't require a fire system unless the cockpit is enclosed. And then only discharged into the cockpit.
Hate to see old irreplaceable stuff torn up like that.
[Re: Clanton]
#2770711
05/03/20 10:41 AM
05/03/20 10:41 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Here is the video, it looks like the fire might have been started by the other car that spun trying to avoid him. Either way I am glad Nick made it out, he was already on his way out when the fire first started it looks like. Scary for sure. Language warning https://youtu.be/DHabMzS2hJo
68 Barracuda Formula S 340
[Re: Clanton]
#2770714
05/03/20 10:46 AM
05/03/20 10:46 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I think the funny car fire suppression systems use foam.
I would not be surprised if the nostalgia front end dragsters had fire systems but I don't know for sure.
Talk to the manufactures I am sure they can tell you what to do.
I am sure nozzle placement is important.
I have not heard the cause of Nick's fire but it looks like the track had little fire fighting capability. I your photo has a full blown fire truck in the back ground and I would be surprised if it was at the track at the time of the crash.
[Re: Hemi_Joel]
#2770785
05/03/20 01:31 PM
05/03/20 01:31 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Halon would be only useful to some degree if you car was stopped/no fan. I am fairly certain if you have a fire, your car will soon come to a stop at some point, and engine will be off. A foam type system would be preferred. And you can always activate the system as car comes to stop, depending on the intensity of fire and how much heat you can tolerate/or pay for. Assuming you are at a legit track, all you are trying to achieve is to contain fire to some acceptable degree until rescue arrives. If it was my car, I would have a dual system, interior/ trunk fuel cell, and engine bay.
[Re: ksj]
#2770790
05/03/20 01:57 PM
05/03/20 01:57 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Nostalgia Top Fuel needs to have an SFI 17.1 system. That's what I would look at. I think gas or foam is optional depending on the application. Definitely foam on an open car.
[Re: CMcAllister]
#2771152
05/04/20 05:23 PM
05/04/20 05:23 PM
Hemi_Joel
Minnesota
Thanks for all the replies. I'm definitely going to look into it.
