I have a 1991 W-150 & a 1990 Ramcharger, both with 241 transfer cases, dana 44 front axle, central axle disconnect, etc, exact same 4wd system in both of them, I'm old school, locking hubs type of guy. Here's my issue: Both trucks in park, all wheels on ground, shifter in 2-HI the Ramcharger front driveshaft will spin freely, the W-150 only turns about 1/4 turn then stops, I'm guessing my CAD actuator is smoked on one, but which one? Should the front driveshaft spin freely when in park 2wd? 4wd worked fine on both last time I used them. Something's not right on one of them obviously, but which one?
